![]() Drives: Ya motha Join Date: May 2017
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 CGM 2SS/RS LS3 Swapped A6 Join Date: Sep 2016
Sounds like the end of the left axle snapped. Wouldn't be surprised if you also had some gear damage.
376 cubic inches of fun
Drives: 2023 Camaro ZL1 A10 Join Date: Jul 2010
The twisted boots alone tell you that there's a problem.
Since both are twisted, there's more damage than just one shaft broken. |
![]() Drives: 2011 Camaro SS Convertible Join Date: Nov 2015
Ouch. Hopefully you can do the work yourself and save some money.
#6 |
Fast Cars and Old Guitars
Drives: 2015 2SS RS (L99, baby!) Join Date: Apr 2012
I think this is why race teams have sponsors. You track it, you break it, they fix it.
#7 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2013 Triple Black ZL1 Vert M6 ECF Join Date: Mar 2011
A club member had a similar experience with her 2010 or 2011 SS back at CamaroFest in Indy as she launched the car on the strip.
Turns out the spider gears in the rear end turned into shrapnel and ruined everything in the diff. |
#8 |
Sooo, did she do something wrong in terms of the launch or is this something related to poor design? Am I to worry if I drive my SS in a "spirited" fashion?
#9 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: All Black 2012 1LS Join Date: Feb 2015
I think the question should be what RPM did the OP launch at . And did he just dump the clutch. How much HP does his car have ? Repeated hard launches can stress parts pretty badly.
#10 |
It really appears you just busted the ball and cage kit in the inner half shaft end. The diff may in fact be fine. That's my guess. You're down there in "The Driveshaft Shop" country. He's a sponsor here. If you knew someone in the bizz, those ends can be replaced. Most won't do that though. But in your case, you probably boogered up the splined end of the shaft that mates with the inner race of the six-ball set up. The twist tells me that. I'd expect the shaft to go before the diff...if yer lucky!
I think all of us weekend warriors worry about this. Our cars were designed much more to be performance passenger cars than race cars. Ok, a ZL1, Z/28 and to a lesser degree, the 1LE are equipped with a few track-friendly mods. Kind of a pay me now or pay me later proposition , IMO. $80K (give or take) gets you a Z/28 track car. But something tells me they break too. Pay to play...
#11 |
#12 |
#13 |
Writer
Drives: 2010 SS / 1967 Camaro Join Date: May 2009
You can find stock take-off axles all over for cheap, so if it's just that you are lucky. If it's the spider gears, you might want to consider all your options.
I have broke both over the years.
PROJECT HEAVY CHEVY
Camaro Now: Mods for the Masses Part I | Part II 13.15@106 1.95 | 100% Stock 12.37@112 1.85 | + Kooks Headers/Cats + 20" 555R + CAI + BW TB + UDP + Tune 12.06@113 1.70 | + CD 3200 + 18" NT05R + RCR Intake + NE OTR + GPI Tune 11.84@115 1.59 | + 3.91s + Race Star 17x7 Fronts 10.90@125 1.47 | + GPI VVT Cam + BW Ported Heads + CD 3800 |
#14 |
| Tags |
| axle, broken, differential, racing |
