![]() Drives: Camaro 2010 Join Date: Jul 2010
Intermittent electrical cut out solved
So my 2010 Camaro SS had intermittent electrical issue . It would randomly turn off for about one or two seconds and then turn back on while driving. The HUD would show weird stuff like reset driver & passenger window move up and down. Then when I'm pulling in the driveway at like 1 mile an hour and turning the wheel it does it again. So I'm like hmmm. So sitting still engine idle I turn the wheel left and right then it does it again. So bottom line my positive battery cable was touching the steering shaft. Maybe the battery cable moved when I did the cam change ia year ago.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 CGM 2SS/RS LS3 Swapped A6 Join Date: Sep 2016
Man, you're lucky you didn't short anything out!
Good find though.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Inferno Orange 2SS/RS Join Date: Apr 2010
Glad you figured it out. As I recall, there were some issues wirh early models battery cables.
Avenging Orange: 43 years of not buying into the Hype........and damn proud of it!! https://youtu.be/9JD9it6SmB8 https://youtu.be/xmelTlEzI34 KICKING CANCERS ASS SINCE 2015!! |
Wow, I hope that horseshoe had lube on it. Glad it was solved without damage or injury.
| Tags |
| cut out, electrical |
