Old 05-11-2017, 05:38 PM   #1
Antbox530
Drives: 2013 1LE
Found the paint code for 1LE wheels
WA8555 as some have said. My local dealer said they couldn't paint them, but gave me the code listed in their system.
Antbox530 is offline   Reply With Quote
Old 05-11-2017, 05:44 PM   #2
608RS
608RS's Avatar
Drives: 2015 2ss
thanks for the info
608RS is offline   Reply With Quote
Old 05-11-2017, 05:54 PM   #3
guerrillakilla13
guerrillakilla13's Avatar
Drives: 2014 Camaro 2SS RS 1LE
I had to paint mine (since I curbed the front right about 3k miles in from brand new). I've never noticed them since, the touch up paint did an incredible job but wasn't perfect. Too bad I'm just now reading this haha
guerrillakilla13 is offline   Reply With Quote
Old 05-12-2017, 11:39 AM   #4
427K
427K's Avatar
Drives: 15 1SS 1LE
Thats really good information to have handy.. Thanks
I spent most of my money on beer and cars, the rest I just wasted.
427K is offline   Reply With Quote
Old 05-12-2017, 06:36 PM   #5
DontWannaBeBumbleBee
DontWannaBeBumbleBee's Avatar
Drives: 2015 2SS/RS/1LE
Great info
DontWannaBeBumbleBee is offline   Reply With Quote
Old 05-25-2017, 11:57 PM   #6
20142SS/1LE
Drives: AGM 2014 Camaro 2SS/1LE
That paint code isn't the correct one, the wheels are a semi-gloss
20142SS/1LE is offline   Reply With Quote
Old 05-26-2017, 03:14 AM   #7
CamaroDreams76
Tri-County Camaro SWFL
CamaroDreams76's Avatar
Drives: 2013 IOM 2SS/RS/1LE
WA8555 is the OEM black color that camaros have I think its GBK if I'm not mistake.
But the AC Delco touch up paint in that color blends extremely well with the semi gloss wheel. I've used it several times to touch up a spot my local idiots..... I mean tire shop I used once created.
Old 05-26-2017, 09:03 AM   #8
domano 68
domano 68's Avatar
Drives: 2014 1LE
Subscrib'd
domano 68 is offline   Reply With Quote
Old 05-30-2017, 07:00 PM   #9
Clarkstar
Clarkstar's Avatar
Drives: 2013 1SS 1LE
So what is the real paint code?
2013 1le- Katech 416 short block, TSP custom grind cam, LOD intake, cnc heads by F.ED., Nick William's 102mm T.B., CORN fed, Pedders coilovers. Performance street alingnment by Justin at Lake Country Alignment and dyno tune by Late Model Throttle.
603 h.p. 495 ft lbs tq.
Clarkstar is offline   Reply With Quote
Old 05-30-2017, 07:32 PM   #10
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
An what brand of paint is the code for??
Orange Krush II
Old 05-31-2017, 07:01 AM   #11
scapone4
scapone4's Avatar
Drives: 2015 SW 1LE
ditto to both lol
scapone4 is offline   Reply With Quote
Old 06-05-2017, 09:53 PM   #12
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
Found this not sure how much it helps it's a few years old.
http://www.camaro5.com/forums/showthread.php?t=369716
Orange Krush II
Old 08-26-2019, 09:17 PM   #13
HOJO
HOJO's Avatar
Drives: 2014 Camaro SS/RS 1LE 1967 Camaro
Oldblue posted the same link and saved some time ago. Should be what you need
HOJO is offline   Reply With Quote
Old 08-26-2019, 10:46 PM   #14
LevonH
Chevy Enthusiast.
Drives: 2015 Camaro ZL1 Summit White
Here's a GM Link
Just change the year in the URL to get your year
http://www.genuinegmparts.com/pdf/to...lity-guide.pdf
Levon H. Bone Stock
LevonH is offline   Reply With Quote
