Old 05-12-2017, 01:05 AM   #1
MarkSS
MarkSS's Avatar
Drives: 2014 Z/28
Nitto track day update
I did my first track day of the year today, also the first on Nitto NT01s. First, a couple of street impressions. (All of this is compared to Trofeo Rs.)
The negative:The Nittos are quite a bit louder, transmitting a fair amount of tire noise to the interior. I find this easy to fix with a combination of radio volume and exhaust.
The positive: the tendency of the front to dart around with Trofeos is all but eliminated with Nittos.
On to the track. I wasn't sure what to do with tire pressures so I started with 32 cold in the front and 31 in the rears for the first session and the car felt terrible. I was concerned that I had made a bad choice. It was squirmy and had a lot of understeer, especially in the fast turn that is part of the oval track at Milwaukee. (I also learned that these tires need a few laps to build heat and it will cost me some time buffing out pylon marks from the front end due to a little "agricultural racing" that happened when the tires were still cold and I pushed a little too hard.) We put a pyrometer on the tires after the first session and it was clear that they all had too much pressure.
I dropped them by 2 psi each for the second session and it was amazing the difference. Understeer was significantly reduced, and the car felt much more planted. I was turning times on a relatively cold track that equaled my best from last season (fastest of 1:17 and consistently in the low 1:18s.)
However, there is still a difference in feel from the Pirellis. The Pirellis have a sharper feel at turn in, which I like, but less forward grip off of corners. The Nittos were great for coming off of corners and I could get on it very early without wheelspin. (I even had a corner worker come and tell me I was lifting the inside front tire on one corner.) Nittos also performed well under braking. One negative: The Nittos felt less sharp on turn in and I wonder if it isn't due to a more rounded outside shoulder. This is my biggest complaint and requires a slightly different driving style, which I was getting used to more by the third session. I am not sure I got the pressure perfect yet either, but will keep playing with that next time.
The tires still looked great after three sessions and seemed to wear evenly, which I hope means that my additional negative camber is paying off. Lap times were basically equal to the Trofeo's on a day that was less than ideal for grip so given the price difference, and as long as they last longer, I would consider another set.
MarkSS is offline   Reply With Quote
Old 05-12-2017, 03:36 AM   #2
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
nice review! I haven't tried anything other than Trofeos on track. Reviews like this are great news when tire purchase becomes necessary. I keep finding good used Trofeos for decent prices and have 6 left before considering something else.
'17 ZL1 A10 Mosaic Black PDR/Nav 2:03.08 VIR Full 11.003@129.2 1.75 (sold)
'15 Z/28 #325 Black a/c & stereo. 2:10.1 VIR Full (sold)
'12 ZL1 A6 Black 10.52@131 1.55 60' 2:13 VIR Full (sold)
Stephen12ZL1 is offline   Reply With Quote
Old 05-12-2017, 06:02 AM   #3
The_Raging_Bull
Raging Bull Reborn
The_Raging_Bull's Avatar
Drives: '09 CGM Z063LZ '15 RH Z/28 #0631
I'm thinking of doing an auto cross with my Corvette Club between OKC and Tulsa, is the consensus that the Trofeo-R's ought to be at 30 to 31 psi after heated up; it will be a warm track as we'll see 80F tomorrow. I'm looking forward to seeing how well the Z rolls over the Vettes; as none of them to my knowledge are running a 3.90 differential; so I ought to have a advantage at acceleration out of the hole. There will be C6 and C7 Z06's
Toy 1 '15 RH Z/28 w/AC & Radio S/N 0631
Toy 2 '09 CGM Z06 3LZ
My DD: '17 Ford Mustang GT
Her DD: '14 F150 Ecoboost 3.5
The_Raging_Bull is offline   Reply With Quote
Old 05-12-2017, 08:05 AM   #4
Stephen12ZL1
Drives: '21 ZLE A10
Because the tires during an autocross never get up to temp, most guys run higher pressures initially like 34-35psi. Just as everything else, you have to experiment. Good luck!
