Old 05-12-2017, 11:42 AM   #1
Lnch Mny
Lnch Mny's Avatar
Drives: IBM Camaro
Drip... Not the oil cooler
Any body seen where the oil drips off the transmission??
Lnch Mny is offline   Reply With Quote
Old 05-12-2017, 11:43 AM   #2
JusticePete
Drives: Camaro Justice
It is engine oil based on color. Check to be sure the filter is tight.
Old 05-12-2017, 01:00 PM   #3
jrhagen
Banned
Drives: Camaro
Rear main.
jrhagen is offline   Reply With Quote
Old 05-12-2017, 01:09 PM   #4
Lnch Mny
Lnch Mny's Avatar
Drives: IBM Camaro
filter is good and oil cooler is clean, replaced it a few years ago. This drip just showed up this year. Bought the car new in October of 2010, has about 24,000 miles on in it.
Old 05-12-2017, 01:19 PM   #5
JusticePete
Pull the aluminum plug / cover. Is the inside of the bell housing dry?
Old 05-12-2017, 05:37 PM   #6
JerTM
JerTM's Avatar
Drives: 2011 2SS/RS M6
With the sight plug removed like JusticePete said you can usually look through the flex plate at the rear main seal to see if it's wet. In my experience over the last 10 years as a GM tech, it's going to be your oil pan gasket. I've changed countless oil pan gaskets on LS engines, haven't replaced a rear main yet.
JerTM is offline   Reply With Quote
Old 05-12-2017, 06:26 PM   #7
jrhagen
Banned
Drives: Camaro
Are you boosted or NA?
Old 05-12-2017, 07:41 PM   #8
1bad1/le
Ed
1bad1/le's Avatar
Drives: 2015 camaro 1le 2ss
Oil pan gasket.
1bad1/le is offline   Reply With Quote
Old 05-12-2017, 08:22 PM   #9
Lnch Mny
Lnch Mny's Avatar
Drives: IBM Camaro
NA with everything but port and polished heads. I'll check it out on Saturday night. We have cars and coffee tomorrow.
Old 05-13-2017, 03:01 PM   #10
JusticePete
Originally Posted by 1bad1/le View Post
Oil pan gasket.
Old 05-13-2017, 09:21 PM   #11
QUICRNU
Drives: Z06 wannabe
Mine had the same oil leak..... It was oil pan gasket.
Apex Focused
QUICRNU is offline   Reply With Quote
