Old 05-15-2017, 04:10 PM   #1
DvKillar
DvKillar's Avatar
Drives: 2015 Chevy Camaro 2LS
Fog light holes for air intake runners
So on my 2015 2LS, I have only fog light holes and vents. no lights.
I was curious if anyone has heard of using the holes to plumb air into air filter. Make a closed system to ram air up to the air box.
would make my otherwise useless holes functional!
I may be stealing this idea from the Dodge Hellcat. I think it was that car that deleted a drivers' side headlight for this purpose.
DvKillar is offline   Reply With Quote
Old 05-15-2017, 05:05 PM   #2
gringo
gringo's Avatar
Drives: Camaro V6
The openings are fairly small and then you would have to make a long tube going to the passenger side hole. The gains would be minimal at best. It would be better to just get fog lights to fill in the holes. It will look a lot better and you will have fog lights. That's what I did.
gringo is offline   Reply With Quote
Old 05-15-2017, 09:09 PM   #3
DvKillar
DvKillar's Avatar
maybe, but solid plastic or aluminum tubes with smooth surface for minimal turbulence, and a clean y-pipe like from an exhaust into 3" collector? sounds like a fun experiment!
Old 05-15-2017, 09:11 PM   #4
sspade
sspade's Avatar
Drives: 2015 Camaro LFX A6
I thought about this same idea (as Im sure other LS owners have) and ended up opting for the factory fog light kit from Gen5DIY.
There is some sort of air scoop available that does not utilize the fog light openings... not sure exactly how it works... can someone post a link to that if they know what Im talking about?
Cold Air Inductions CAI : Apex Air Scoop / WW Relocate Kit : JacFab Intake Manifold Spacer : Overkill 80mm Throttle Body : Overkill Tuned : MagnaFlow Cat-Back Exhaust : Elite Engineering Catch Can : ZL1 Strut Tower Brace : Custom Tunnel Brace : JPSS Caster Locks : JPSS 32mm Rear Sway Bar : JPSS Billet Radius Arm Bushings : Pegasus Solid Sub Frame Bushings : 1LE Brembo Conversion : B&M 70273 Trans Cooler
sspade is offline   Reply With Quote
Old 05-15-2017, 09:15 PM   #5
DvKillar
DvKillar's Avatar
there are scoops available, but they look underwhelming. like a 2" x 4" rectangular opening thru odd angles into bottom of filter thru the grill.
I'm sure it works, but seems like an after thought vs real engineering
Old 05-15-2017, 09:17 PM   #6
DvKillar
DvKillar's Avatar
how about using a spiraled entrance with louvered fins to encourage air flow into collector?
Old 05-15-2017, 09:18 PM   #7
DvKillar
DvKillar's Avatar
maybe a wind\pressure driven propeller with led's ? faster you go, the redder it gets! sweet!
Old 05-15-2017, 11:22 PM   #8
sixtyseven
sixtyseven's Avatar
Drives: 2015 Camaro 2LT/RS 2017 XL1200C
That's actually a good idea. You would only need to use the drivers side opening. There was a guy here last year selling home made air scoops built out of vinyl rain gutter/elbows that were cut/fitted and pop riveted/glued I believe. You than have the passenger side to cool something down with using some imagination and engineering.
2015 2LT/RS Black -w- CGM Rally Stripes. CAI, Elite CC, Apex air scoop + w/b kit, JacFab ported IM/Extendolator, Solo HFC's, Corsa Sport Cat-Back #14953, GM strut brace, GM stealth splash guards, GM premium floor mats, Defenderworx two tone sills, Emblem Pro LFX hood emblems, FR41-20x9/20x10 gloss black wheels, OK91/93 - OKTCM Tune.
sixtyseven is offline   Reply With Quote
Old 05-16-2017, 05:43 AM   #9
rtcat600man
having FUN now 13.66@101
rtcat600man's Avatar
Drives: 2010 2LT IOM
Yes, the added air will be a benefit if you can help direct it to an after market air intake. Example CAI system is a sealed box, directing extra colder air towards the bottom of the box will help.
Cutting away some of the opening behind the grill helps get air to this area too. This is what the scoop performance does, it is not an engineering after thought as the stock set-up does have a scoop that draws from the front grill. Adding the after market box, is what drives the benefit of the scoop, which helps draw air from the front, instead of letting it draw from the engine heat soaked air.
Old 05-16-2017, 08:54 AM   #10
sspade
sspade's Avatar
Can you post of link of this scoop please?
Old 05-16-2017, 09:19 AM   #11
DvKillar
DvKillar's Avatar
here is the one I found.
http://www.gen5diy.com/Chevrolet/Cam...rake-duct-zl1/
Old 05-16-2017, 09:31 AM   #12
DvKillar
DvKillar's Avatar
Also, Reading thru Yzark's build article, he found an Apex air scoop and swears it made huge improvement. but I have not located one myself.
http://www.camaro5.com/forums/showth...=315604&page=4
Old 05-16-2017, 03:54 PM   #13
rtcat600man
This is not the scoop for the air intake. The Apex post you had is the one you are looking for.
Can be bought from here.
https://www.phastekperformance.com/P...maro-83115.htm
Old 05-16-2017, 03:58 PM   #14
rtcat600man
Here are some threads on the install.
http://www.camaro5.com/forums/showthread.php?t=335733
https://southjerseycamaro.com/review...kit-air-scoop/
air intake, fog lights
