05-18-2017, 07:40 AM | #1 |
Drives: 2015 Camaro 2SS 1LE Join Date: Feb 2015
Need help with agp kit issue
hi guys. When I installed my kit I think I might have forgotten to zip tie the wires that run next to the transmission. It clearly said it on the instructions but I think I didn't take that step into considerations and got ahead of myself. Ever since the car was finished it like if something was burning(plastic). I thought it was part of the break in process where chemicals and stuff was being burnt out of the exhaust and hot parts. The smell continued but I became immune to it and didn't notice it for a while. Now my car loses power steering gauges go nuts abs goes check engine light comes on traction control light comes on. It's a damn mess. I don't know if it might be those wires, or something else? Need help guys. Thanks! (Trying to get this fixed so I can do ARP head studs and a head gasket so I can up the boost RIP) lol
AGP Twin turbo kit, base 54/57 Borg Warner turbos, TSP stage 4 N/A cam, AGP twin 430lph e85 pump fuel system w/ flex fuel sensor, 1000cc FIC injectors, Grimm speed manual boost controller. (830 rwhp 778 rwtq @ 15.5 psi)
05-18-2017, 09:07 AM | #2 |
Drives: 2014 SS 1LE Join Date: Apr 2014
That's really the only major harness that's near hot parts on this kit. I would get it up in the air and see if you can check to see if the pass side manifold adapter is burning it up. I wrapped mine in heat wrap and raised it up with a metal strap and haven't had any issues. I know there were a couple people that had the same issue.
05-18-2017, 09:10 AM | #3 |
I would put the car on a lift or jack stands and then check the harness on the passenger side,
Cai intake and a few other mods😎
05-18-2017, 09:12 AM | #4 | |
05-18-2017, 09:34 AM | #5 |
What consist of the harness next to the tranny? And is it replaceable? Because I'm sure mine is toast. Literally........
05-18-2017, 09:50 AM | #6 |
Resident nomad
Drives: 2014 Summit White 1SS/1LE Join Date: Nov 2015
First off dude, don't mean to beat you up (I know you're doing that already), but why didn't you take action as soon as you smelled it? You put a lot of $$ and sweat equity into that, to get it back up and double check your work is too small an effort to ignore. Enough of the obvious.
I would guess you do have an electrical issue, possibly a short or ground issue. A short could definitely be caused by melting wires.
Sold:
2007 Z06 2002 Viper GTS/ACR 2003 Z06 1965 FFR Cobra 2012 Nissan 370Z ADM LSA Stage II, Roto-Fab CAI, Kooks LTH/HFC's, Phastek CC, ported TB, Mishimoto radiator and oil cooler, BC Racing ER Series CO's, JPSS 32mm Black Magic rear bar, JPSS front inserts, R1 Concepts Premier slotted rotors/Goodrich SS lines, Schroth ASM harness, MGW flatstick, Brey-Krause HB, Tuned by NicD, at Cordes Performance Racing. |
05-18-2017, 12:49 PM | #7 |
Is it replaceable yes but it will be a pita, if your lucky you will be able to salvage the harness but on that note there have been a couple people that have done the same thing and had to replace the harness but they did it while the motor was out i believe, so good luck man and now you just need to crawl under and check out the where the damage is and how bad
05-18-2017, 02:03 PM | #8 | |
Drives: 2015 Camaro SS commemorative Join Date: May 2015
05-18-2017, 02:07 PM | #9 | |
05-18-2017, 02:17 PM | #10 | |
Drives: Black 2SS RS w/White Stripes Join Date: Mar 2011
But the other issues you are complaining of is something completely different. Good luck hopefully you caught it soon enough!
2010 2SS/RS "ChriSStine":
Pat G Custom Turbo CamMotion Camshaft | AGP TT BB Garrett 62/65's | AGP/Fore Triple Pumps | ID1700X Injectors | Alky Control Twin Nozzle Meth | Custom 3" Exhaust | 3.27 gear set w/ Tru Trac | McLeod Twin RXT | Barton Short Throw Shifter | 6th Gen ZL1 Wheels | BMR 1.4" drop springs | Pfadt rear trailing arms & tie rods | Installed by Me & Tuned by Pat G |
