Old 05-18-2017, 03:00 PM   #1
FLSS
Drives: 2010 SS M6
2010 SS, Stabilitrack WITH ABS light
Motor is running fine and appears to have no performance loss... I checked spark plug wires to make sure of positive connection.
I took out all of the wheel speed sensors and checked them and cleaned them also checked the connections on the inside of the firewall and the the connections in the rear end as well, they all visibly look to be fine "not broken etc"...
I put everything back together and still... all my lights are on
ABS, traction control, sport mode etc... no check engine light.
Someone help me out this is driving me bonkers.
FLSS is offline   Reply With Quote
Old 05-18-2017, 04:36 PM   #2
FLSS
Drives: 2010 SS M6
Update:
1. Pulled fuze #40 looks perfectly fine
2. Checked ground wires everywhere, all appear to be good.
3. Battery voltage when car is off is 12.5ish and 14.5 when idle in the drive way.
4. Cleaned each speed sensor and checked for cracked wires
5. Checked the connection from speed sensor to plug.
6. Disconnected Battery several times to see if it would reset.
My local stealership, I mean dealership does not have the most outstanding track record, in fact there terrible.
What other options am I looking at now? Could the wheel speed sensor be bad and look fine? how to check
I saw a youtube video of what looked like a ring on the back of a hub where the ABS sits and it was cracked and missing??? causing this issue on a v6 car... Not sure how to visibly check this unless I take everything under the sun off and visually look at it....
Old 05-19-2017, 10:23 AM   #3
FLSS
Drives: 2010 SS M6
Halp ;/?
2010 SS, Vararam CAI, Texas Speed 1 7/8 LT's no cats, dumped exhaust at the rear axle. Texas speed 231/236 Cam....n20 in the future?? 470/420
Old 05-19-2017, 04:58 PM   #4
sixty9fordkiller
Donkey Dick Cam Camaro
sixty9fordkiller's Avatar
Drives: 2010 2SS/RS LS3 M6
What mods do you have done to the car???
Bone Stock
sixty9fordkiller is offline   Reply With Quote
Old 05-19-2017, 05:14 PM   #5
sixty9fordkiller
When i first got the Vitesse Throttle Controller (VTC), it caused this exact same symptom you just mentioned (July 2016). It did not trigger a check engine light at all but all the abs, service stabilitrak, traction control off lights all came on and stood on. Hooked up the tech2 scan tool and bcm was saying the "brake module" and "yaw rate sensor" were bad. My local tuner said the reason the check engine light didnt light up was because it wasnt emissions or engine/transmission related. Off the bat he said the VTC's signal was not what the car's computer was expecting and that THAT was what triggered the stabilitrak lights and added that the yaw rate and abs need the signal from the accelerator pedal to the throttle body to be consistent in order to be able to properly control the engine speed/timing in the event of acceleration traction loss/panic braking/wet condition sliding. He recommended that i not erase the BCM trouble codes and instead remove the VTC and let the car cycle for ~200 miles and that IF the VTC was the issue, the BCM would shut off all the lights on its own after it no longer sensed the incorrect throttle signal. So I removed the VTC, drove from Los Angeles to Riverside and back and the lights all turned off after about 220 total miles and havent returned ever since. Going on 10 months now.
Bone Stock
Old 05-20-2017, 06:48 PM   #6
FLSS
Drives: 2010 SS M6
Headers/cam/no cats/ vmax tb/ vararam intake
To the above poster, I'm not sure what your referring to when you say the name of that controller. Is that aftermarket??
Old 05-20-2017, 06:51 PM   #7
FLSS
Drives: 2010 SS M6
So it could have something to do with my throttle body? This issue occured very very shortly after my cam/ TB install and has been that way ever sense.
Old 05-20-2017, 07:48 PM   #8
hunter1660
hunter1660's Avatar
Drives: 2011ss/rs camaro
Disconnect the battery and see if it resets....
. OBX LTH,Rotofab,Magnuson Heartbeat.AEM wideband, HP Tuners
hunter1660 is offline   Reply With Quote
Old 05-20-2017, 10:08 PM   #9
FLSS
Drives: 2010 SS M6
I should add that to the list, I have also disconnected the Battery several times.
Some other symptoms that may be worth Noting.
1. When I start the car the DIC is shows stabilitrak, lights etc. I roll out of the driveway at slow speeds and they all go off for a brief period maybe 5-6 seconds, and then it pops back on. I hear no surging or anything from the ABS module.
2. This only happened one time, but I should mention it I guess. I started my car one day leaving work and it actually went about 14 miles before the issue occurred. 99.9% of the time, the above happens.
Old 05-22-2017, 10:13 AM   #10
Romeloc
Romeloc's Avatar
Drives: 2010 Black 2SS RS A6 Inferno
for a while now my service stabilitrak comes on only if I hit the gas a little hard and then it goes off
[SIGPIC][/SIGPIC]2010 Camaro Black 2SS/RS A6 Inferno Interior Polished Rims, Sunroof
Born 11/19/09
mods:
20% tints
Borla Atak cat-bak
Roto-Fab intake
amber footwell, dome, and trunk lighting(AAC)
Decepticon Gas door
Led Taillights (technostalgia)
Romeloc is offline   Reply With Quote
Old 05-23-2017, 09:31 AM   #11
FLSS
Drives: 2010 SS M6
There are so many threads on here with this problem, yet no one has really figured this out... or have they and not posted?
I'm out of ideas... except to take it to my sub par stealership... what to do.
Old 05-24-2017, 01:57 PM   #12
sixty9fordkiller
who tuned the car for you when you got your cam installed?
Bone Stock
Old 05-24-2017, 02:03 PM   #13
sixty9fordkiller
from experience, i would recommend you have the car checked by a tech 2 at your dealer to read the data from the body control and brake modules. A regular hand held engine DTC reader will not read these. I've seen this kind of scenario happen from a bad hub bearing in the rear causing an overactive ABS sensor reading. That is the best advice i can give you. Your chevy dealer wont erase the BCM codes unless you get the issue fixed and if you decide to take it to a normal average joe shop, dont let them erase the codes unless they've 100% identified and repaired the problem. Take it to someone you really trust if you arent going to take it to the dealer to check BCM data
Bone Stock
Old 05-25-2017, 09:48 AM   #14
FLSS
Drives: 2010 SS M6
Efi alchemy in green cove springs did my cam and tune.
I guess I have to suck it up and take it to the dealership,
They just quoted me $140 plus tax for a set of factory
Spark plug wires. What a joke :/
