Old 05-19-2017, 01:20 AM   #1
briancamaross
briancamaross's Avatar
Drives: 2011 ss 2ss auto camaro
Gears
So I'm thinking about doing 3.91 gears. Now since I have a 27 inch tire will that be to much? With tire size 285 40 18 and 3.91 gear that put me at 4.15 ratio,is that to much for a 6l80 and 3200 stall?
briancamaross is offline   Reply With Quote
Old 05-19-2017, 02:48 AM   #2
Bo White
Bo White's Avatar
Dont fear the gear
2015 2SS 1LE Clutch reservoir, Vararam DRX, ported TB, TSP 2" headers, MGW shifter, stage 4 cam and Wilkes 11° 65cc heads
Totalled:
2010 1SS Wilkes Performance/Eagle 416 shortblock, TSP custom valvetrain, PRC 260 heads, Edelbrock Pro Flo 102, th400 swap, 8" PTC 5500 stall= 535/435 at the wheels tuned Gen 3 Performance and Dyno 10.97 @ 124 full weight in 3100 DA CamaroFest X
Old 05-19-2017, 02:57 AM   #3
briancamaross
Lol I think the gear would improve my 1/8and 1/4 a good amount.like you said a bunch of time Bo white 5th gene auto should of had a better gear from get go. I want to get lower 7s on stock heads went 7.4 at 94 so gears should get me close I would hope. What do you think
Old 06-03-2017, 06:25 PM   #4
briancamaross
So a update got my gears installed with my 27 inch tire it's a 4.15 ratio got 100 miles on it so far everything good to go so far I also had the bmr diff bushings in. I can hear a Little noise from that it seems can't wait to get 500 miles change the fluid and see what it does .70 mph is about 2400 rpm
Old 06-03-2017, 07:34 PM   #5
Bo White
Bo White's Avatar
Awesome!
Totalled:
Old 06-04-2017, 10:33 PM   #6
QUICRNU
Drives: Z06 wannabe
I guess that just seems huge gear?, but maybe because I have a blower?
*shrug* what rpm is that thing going to trap at?
Apex Focused
QUICRNU is offline   Reply With Quote
Old 06-05-2017, 07:14 AM   #7
briancamaross
I'm n/a and I don't know yet but I did figure out the ratio though. I shift at 6800 red line 7000 first gear is 33mph second is 56 third is 86 4th is 114 5th is 155 and 6th is 199mph
Old 06-05-2017, 10:10 PM   #8
QUICRNU
Drives: Z06 wannabe
Is that when you command the shift, or when it actually shifts?
just want to make sure you trap in 4th off the limiter.
Apex Focused
Old 06-05-2017, 11:36 PM   #9
CamaroFred
CamaroFred's Avatar
Drives: Miss Con Ception
My calculator shows those speeds at 6500RPM.
You should be able to hit 121 in 4th @ 6800, 125 @ 7000.
2011 1SS/RS LS3 CGM
CamaroFred is offline   Reply With Quote
Old 06-06-2017, 01:18 AM   #10
briancamaross
I command it to shift at 6800 red line is 7000 rpm . I'm at 215 miles cant wait for the 500 miles change fluid and see how it goes. Gonna need new drag radials.
Old 06-13-2017, 09:30 PM   #11
QUICRNU
Drives: Z06 wannabe
Apex Focused
Old 06-23-2017, 08:45 PM   #12
JLGO
JLGO's Avatar
Drives: 2015 Camaro SS convertible L99
It shouldn't have a noise at all. I just got mine install today with no noise. But I had the techs put the GM 1LE gears along with Richmond's master install kit which is a basically a rebuild kit.
I was told to drive it easy for 500 miles then change fluid. Then drive it normal for 500 miles then change the fluid again.
JLGO is offline   Reply With Quote
Old 06-24-2017, 09:22 AM   #13
Royal Tiger
Drives: 2013 2SS/RS Convertible
I was told I didn't need to change the oil at 500 miles since they installed GM gears. You don't change the oil on a new 1LE at 500 miles. Now I'm wondering if I should just change it to be safe.
Royal Tiger is offline   Reply With Quote
Old 06-24-2017, 05:14 PM   #14
mydreamcar
My Dream Car
mydreamcar's Avatar
Drives: 2011 SIM LS3 1SS
No noise on mine, did the gear oil change at 750 miles. Love this mod. Probably the best one out of the work I had done on the car
CAI intake/ADM Scoop/Stainless Power Headers/Dynatech cat back exhaust/Vitesse Throttle Control/ Ported Throttle Body/QTP Electric Cutouts/ 3.91 gears and janetty rear posi/ Tuned by Janetty racing
mydreamcar is offline   Reply With Quote
