Old 05-20-2017, 01:32 PM   #1
tuki3388
tuki3388's Avatar
Drives: 2012 Camaro 2Ls
Misfires again...
Okay guys i'm really at a loss for words this time. I'm out of all warranty's, past the 5 year mark, and I have been having misfires from my car since the first couple years of owning it. It is a P0303 code that keeps coming back...
2012 Camaro 2LS
51k miles
Swapped coil packs
Cleaned carbon build-up 2x
Valves Cleaned Multiple times
Multiple new plugs
Multiple new injectors
Multiple new coils
3 dealerships ether can't fix it or get it to happen for them.
Got GM involved the last go around.
Thanks in advance!
tuki3388 is offline   Reply With Quote
Old 05-20-2017, 01:45 PM   #2
Swacer
Drives: 2018 GT350
Trade in
Not the most helpful answer sure, but easier than the headaches you're going through.
Off to the Dark Side
Swacer is offline   Reply With Quote
Old 05-20-2017, 01:49 PM   #3
tuki3388
tuki3388's Avatar
Haha yeah i've thought about it. It is just so close to paid off. That and I start my Masters Degree in the fall. Will definitely keep it in mind though.
Old 05-20-2017, 01:54 PM   #4
JerTM
JerTM's Avatar
Drives: 2011 2SS/RS M6
Get the valve springs checked. I fought an intermittent misfire on a 3.6L a few months ago. The valve spring was broken but wedged in a way that it would be fine for a while and then it would misfire a few days later. Yours may not be broken but it could be weak.
JerTM is offline   Reply With Quote
Old 05-20-2017, 02:01 PM   #5
tuki3388
tuki3388's Avatar
Ill note it down thank you!
Old 05-20-2017, 02:14 PM   #6
John_C
LSx FTW!!!
John_C's Avatar
Drives: 2010 Camaro 2SS RS
Check for vacuum leaks. They can cause all sorts of issues. Especially in the fuel system.
Had a Mustang with vacuum leak at the fuel tank that would buck, surge and miss.
2010 2SS RS A6 781rwhp on E85
Stage 2 ProCharger D1X
Circle D 3400 Triple Disc
Kooks Jet Hot Headers
Kooks Full 3in exhaust
Trick Flow GenX 255's
Polished PAC .660's & Ti-retainers
TSP VVT 3.2 cam kit w/DoD Delete
Smith Bro's Trunnion kit
AEM X-Series OBDII Widebands
FIC ID1300x Injectors
GM ZL1 High Output Fuel Pump
DSX Tuning Flex Sensor
DSX Auxiliary Fuel System
Tim King Stage 4 Max Effort CTSV 6L90
DSS 1 piece aluminum driveshaft
JRE 6L80E / 6L90E Dipstick
NGK Iridium IX spark plugs #7 heat range
Mighty Mouse Camaro 5 Wild w/-12an and Billet Black
HP Tuners VCM Suite
John_C is offline   Reply With Quote
Old 05-21-2017, 05:26 PM   #7
tuki3388
tuki3388's Avatar
okay didn't know that but I will get it checked out.
Old 05-21-2017, 06:03 PM   #8
JerTM
JerTM's Avatar
Although it couldn't hurt to check, a vacuum leak is highly unlikely to cause a misfire on one cylinder only.
Old 05-21-2017, 09:38 PM   #9
Yasuo
Yasuo's Avatar
Drives: 2010 Camaro SS LS3
Well, have you ever had any overheating issues? Oil leaks in the past? It's a long shot but have you checked to make sure your piston rings and cylinder walls are ok? A good way to check it is to check the compression of the actual cylinder itself and compare the psi reading to the other cylinders which are firing properly. If the psI reading is substantially low, pour some oil directly into the cylinder and check the compression again. Pouring oil into the cylinder will act as a temporary seal on the cracked piston ring and will bring the compression back up to normal until the oil is burned off. If that's the case, you're going to have to rebuild that cylinder.
Yasuo is offline   Reply With Quote
Old 05-21-2017, 10:40 PM   #10
hammdo
'It's an experiment'
hammdo's Avatar
Ck cylinder #3 for the mis-fire. I'd ck the valve spring, wire, and plug. Also, those 'cleaning' sprays can cause issues if it released 'hard' carbon in the cylinder.
Has any mechanical work been done that may impact the misfire? Have you also checked the ground to the engine?
Did you do a compression and leak down test on the offending cylinder?
Just some suggestions...
-Don
747 RWHP 794 RWTQ
2ls, misfire, p0303, tuki3388
