Old 05-21-2017, 07:36 PM   #1
Ooodang15
Drives: 2015 Chevy Camaro 1SS
is a 700whp BTR stage 3 NA cam,whipple e85 possible?
I currently have a BTR stage 3 NA cam, ATI 10% underdrive pulley and supporting top end for the cam. I'm making 470hp and 432tq. Im looking at taking the next step in adding power and adding some boost to my life. I know my stock ZL1 pump that was put into the 14-15 SS can't handle much more than 650. Can i make 700 with the cam I have now with a whipple and E85 flex fuel? What size injectors do you guys recommend for this and what fuel pump? Should I swap out the BTR NA cam for a BTR stage 3 blower cam? Any advice would be awesome!
Ooodang15 is offline   Reply With Quote
Old 05-21-2017, 07:47 PM   #2
ttshovel
ttshovel's Avatar
Drives: 12 camaro ss, 72 chevelle, 91camaro
the zl1 pump can't handle much power on e85. have to go with twin 450 pumps for that. I made it into that club but it was a lot of extra parts with a lsa blower. if I could do it over again I would've went with the agp twin kit from the start.
ttshovel is offline   Reply With Quote
Old 05-22-2017, 07:16 AM   #3
DSX Tuning
Drives: 2019 Corvette ZR1
My auxiliary pump system would give you the overhead you need for fuel volume.
DSX Tuning is offline   Reply With Quote
Old 05-22-2017, 07:37 AM   #4
Dwright
Drives: 2011 Camaro 2ss
You will need to get rid of the 10% under drive pulley as well. This will lower the boost from the supercharger
Dwright is offline   Reply With Quote
Old 05-22-2017, 08:15 AM   #5
Ooodang15
I was looking at the AGP TT kit for awhile now But how would I mount the turbos in the engine bay?
Old 05-22-2017, 08:19 AM   #6
Ooodang15
Thanks for the heads up, good thing I kept the stock one
Old 05-22-2017, 09:49 AM   #7
Moreair1
Moreair1's Avatar
Drives: 2011 ss convertible
Agp tt kits are bottom mount, if you want top mount you would have to do a different manufactor,
Cai intake and a few other mods😎
Moreair1 is offline   Reply With Quote
Old 05-22-2017, 09:53 AM   #8
camarosspower
camarosspower's Avatar
Drives: 2010 camaro ss
Looks like that's the hellion TT kit not the agp TT kit
camarosspower is offline   Reply With Quote
Old 05-22-2017, 02:26 PM   #9
stevieturbo
Drives: it changes
That is not AGP, AGP turbos are down low as others mention, so would lend themselves well to doing a TT and blower setup if you wanted!
stevieturbo is offline   Reply With Quote
Old 05-22-2017, 02:29 PM   #10
UNRIVALED SS
UNRIVALED SS's Avatar
Drives: 2010 Camaro SS
Send a message via Yahoo to UNRIVALED SS
Answer
The answer is yes.
You need a big time dual pump fuel system and 1300 cc injectors minimum.
UNRIVALED SS is offline   Reply With Quote
Old 05-22-2017, 04:05 PM   #11
ttshovel
ttshovel's Avatar
Originally Posted by UNRIVALED SS View Post
The answer is yes.
not true as far as injectors go. I made 730whp with 1000s. could have raised base pressure and made more on them.
Old 05-22-2017, 04:09 PM   #12
Ooodang15
I'll take a look at the hellion TT kit then
Old 05-22-2017, 04:12 PM   #13
Ooodang15
The answer is yes.
Any recommendations as to what fuel system I should run?
Old 05-22-2017, 05:35 PM   #14
Moreair1
Moreair1's Avatar
Fyi Heat management(turbo blankets/wrap ect.) is critical for any turbo system that places the turbos in the engine bay.
