05-25-2017, 09:47 AM | #1 |
When is enough ever...
Drives: 2006 Silverado 2500HD CC/SB LBZ Join Date: Apr 2011
Location: Residence: Chula Vista, CA Home: Billings, MT
MRR M017 Wheels for HPDE
I've been out of the game a couple years since my engine let go at Streets of Willow. Finished building my monster NA 427 last year but then moved to PACNORWEST. Finally in a position to get back on the track but need to get some real rubber under the car. 575rwhp is too much for stock SS wheel/tire combo. Would like to go Forgeline but not in the budget so now I am looking at MRR as a possible solution. Any inputs on how they hold up, fit, or anything else? Looking to run the 20x10 front and 20x11 rear. Car is lowered ~1.25". Thanks.
The Project: 2011 Camaro 2SS/RS (ERL 427 Superdeck NA Monster)
"Just like farmer engineering. Find the weak link and fix it, then find the next one." Salt Cat Racing |
05-25-2017, 01:19 PM | #2 |
Drives: 2010 2SS/RS Join Date: Dec 2009
There cast just like our SS wheels and most don't recommend for tracking. Plus there heavy now they have a set of rotary forged that are a compromise between true cast and true forged with a decent price tag.
Orange Krush II
05-25-2017, 03:30 PM | #3 |
Looked to me like they are advertised as rotary formed like most of the other aftermarket wheels we are seeing and the weight were reasonable as well at and advertised 25lbs.
Sent from my iPad using Tapatalk
05-25-2017, 03:52 PM | #4 |
Drives: 2015 Summit White 1SS/1LE Join Date: May 2015
For forged track wheels, take a look at Finspeed. finspeed.com
Lightwieight, forged, custom, made in the US. |
05-25-2017, 04:18 PM | #5 | |
Ok I'm interested. Whose running them and who's selling them? Sent from my iPad using Tapatalk
05-26-2017, 11:03 AM | #6 |
Scratch that. Price quote is too rich for my blood. Basically coming in the same as Forgelines which I'd like to run but $$$.
05-26-2017, 11:28 AM | #7 |
Drives: 2013 1LE 1SS Victory Red 1 of 76 Join Date: Sep 2008
I've been running the MRR FS01's for the last couple of years. The are flow forged and fairly light. No problems at all. If you have any interest I'll be selling my 19x10 fronts and replacing them with 11's. $300 per wheel. They are gloss black.
2013 1SS 1LE Victory Red. 187 CAM-C
05-27-2017, 08:53 PM | #8 |
Pretty sure I'm going with Z M017 staggered setup. Just shopping around before I approach "the boss" for some funds.
05-28-2017, 10:44 PM | #9 |
Drives: 2018 Camaro ZL1 1LE Join Date: Apr 2015
I'm running the mrr m017 wheels on track and they are flow forged and weight 25lbs, they are great wheels for the price.
06-03-2017, 11:00 PM | #10 |
2017 1LE Wheels on 2011 SS
Well I was planning on the MRRs and then someone was trying to talk me out of running them on the track. Was in a quandary about what to run and then, factory 2017 1LEs came into the picture.
"Just like farmer engineering. Find the weak link and fix it, then find the next one." Salt Cat Racing Last edited by tadams72; 06-05-2017 at 12:02 PM. Reason: Different Direction |
06-03-2017, 11:03 PM | #11 |
Instagram: Sangstah
good choice, those look great
2019 SS 1LE - "CaSSandra" 2014 SS - "AleSSandra - Sold" 94 Z28 - Sold Follow the build https://www.camaro6.com/forums/showthread.php?t=612717 |
06-04-2017, 05:34 AM | #12 | |
LSx FTW!!!
Drives: 2010 Camaro 2SS RS Join Date: Jan 2017
So they fit perfectly? Got pics of how much they stick out of the fenders? Sent from my iPhone using Tapatalk
2010 2SS RS A6 781rwhp on E85
Stage 2 ProCharger D1X Circle D 3400 Triple Disc Kooks Jet Hot Headers Kooks Full 3in exhaust Trick Flow GenX 255's Polished PAC .660's & Ti-retainers TSP VVT 3.2 cam kit w/DoD Delete Smith Bro's Trunnion kit AEM X-Series OBDII Widebands FIC ID1300x Injectors GM ZL1 High Output Fuel Pump DSX Tuning Flex Sensor DSX Auxiliary Fuel System Tim King Stage 4 Max Effort CTSV 6L90 DSS 1 piece aluminum driveshaft JRE 6L80E / 6L90E Dipstick NGK Iridium IX spark plugs #7 heat range Mighty Mouse Camaro 5 Wild w/-12an and Billet Black HP Tuners VCM Suite |
06-04-2017, 12:32 PM | #13 | |
I think they are going to be good. Car is slightly lower which will be good on the track but might make parking lots a bit more challenging. I've still got to get out and check lock to lock, suspension compression, etc on a drive but fender clearance was the biggest concern and it doesn't look to be an issue at all. Sent from my iPhone using Tapatalk
06-05-2017, 12:08 PM | #14 |
Well the fit is good. On the test drive the feedback at the steering wheel is incredible. steering input is "right now". I think driving this car on the track is going to be fun once I learn the car's capabilities and can read the feedback. Almost like getting behind the wheel of a totally different car. Oh, and MUCH more rear grip. I was able to roll into the throttle much harder before the rear kicked loose.
