Old 05-26-2017, 09:09 AM   #1
domano 68
domano 68's Avatar
Drives: 2014 1LE
2014 1LE Rim Width Clarification
According to this document from Chevrolet, for the 2014 1LE the front and rear rim widths are the same, 20x10.
I've read here that the rear's are 20x11. Was that for 2013 and prior?
See page 5 of attached document. Thanks.
domano 68 is offline   Reply With Quote
Old 05-26-2017, 09:18 AM   #2
Billy10mm
Billy10mm's Avatar
Drives: 2014 Camaro 2SS 1LE NPP
Rim widths for all 5th gen 1LEs are 10" front, 11" rear. Tires are square, 285s on all four corners. I saw where the PDF had it wrong. They are not 10" in the rear. Damn marketing department keeps f*cking things up.
My thoughts on some things:
  • Driving Nannies: If I'm that far out of shape on the street, something has gone terribly wrong and by all means Mr. Computer man, come and get me.
  • G2s: Rock throwing is like like a tramp stamp; although problematic, it's a sign of good things to come.
Billy10mm is offline   Reply With Quote
Old 05-26-2017, 10:23 AM   #3
BeMe
Drives: '14 1LE
If you look inside your wheels, you'll see they have the width listed.
BeMe is offline   Reply With Quote
Old 05-26-2017, 10:28 AM   #4
14Black1LESS
14Black1LESS's Avatar
Drives: 2014 2SS/RS/1LE
Its definitely wrong. I have 315 tires on the rear of mine and I could be wrong but I'm pretty sure a 315 will not fit on a 10" wide wheel.
14Black1LESS is offline   Reply With Quote
Old 05-26-2017, 11:20 AM   #5
domano 68
domano 68's Avatar
Drives: 2014 1LE
Did not know this. Thanks!
Old 05-27-2017, 10:26 AM   #6
domano 68
domano 68's Avatar
Drives: 2014 1LE
Is 110 ft-lbs the correct wheel nut torque for these 1LE wheels? Thanks!
Old 05-27-2017, 10:49 AM   #7
nilfinite
Drives: Camaro 1LE
Yes, that is correct. Some earliest Camaro had an even higher torque spec but the later model years are 110.
nilfinite is offline   Reply With Quote
Old 05-27-2017, 12:17 PM   #8
Olddudesrule
Resident nomad
Olddudesrule's Avatar
Drives: 2014 Summit White 1SS/1LE
You can definitely tell if have even accidentally mounted a rear wheel on the front....wonder how I know that
Sold:
2007 Z06
2002 Viper GTS/ACR
2003 Z06
1965 FFR Cobra
2012 Nissan 370Z
ADM LSA Stage II, Roto-Fab CAI, Kooks LTH/HFC's, Phastek CC, ported TB, Mishimoto radiator and oil cooler, BC Racing ER Series CO's, JPSS 32mm Black Magic rear bar, JPSS front inserts, R1 Concepts Premier slotted rotors/Goodrich SS lines, Schroth ASM harness, MGW flatstick, Brey-Krause HB, Tuned by NicD, at Cordes Performance Racing.
Olddudesrule is offline   Reply With Quote
Old 06-04-2017, 03:29 AM   #9
Powered1le
Powered1le's Avatar
Drives: 2014 2ss 1le
20 x 10 front 20 x 11 rear
2014 camaro 2ss/rs 1le [muffler & resonator delete, x-pipe , roto fab cai, 305 35 r20 rear tire 285 35 r20 front goodyear f1 supercar,1 7/8" tsp long tube headers with high flow cats, tsp Prc heads, K1 rods, Wisco pistons, 522whp 495tq, dynojet, btr stage3 cam kit, arp head studs and arp bolts.
Powered1le is offline   Reply With Quote
Old 06-06-2017, 09:30 AM   #10
paul84043
paul84043's Avatar
Drives: 2015 Camaro 2SS RS 1LE
Every time I take my car in for service they ask me if I want my tires rotated.
Facepalm every damn time. It's really scary actually.
paul84043 is offline   Reply With Quote
Old 06-06-2017, 12:10 PM   #11
Camaro_Corvette
36.58625, -121.7568
Camaro_Corvette's Avatar
Drives: Team 1LE
Same. At least they put your oil cap back on. Mine didn't. Lesson learned.
