![]() Drives: 2013 Ashen Gray 2SS Join Date: Dec 2014
Night owl halo issue
I have had night owl halos installed on my 13' SS for around 2 years, and have the default colors set to white on startup, however, my driver side halo is purple even when set to white, while my other halo is the regular white. This just started happening. Every other color is accurate, but when set to white, it flickers between white and purple and then stays purple. Any suggestions?
2013 Ashen Gray 2ss L99, 20" Giovanna Shaki, 315/275 Nitto Invos, Texas Speed 1 7/8'' Headers, Lingenfelter Axleback Dyno tune by PowerFab, Black Heritage Grill, Oracle Afterburners 2.0 P13W fogs with DTRL harnesses, Night Owl Halo kit, Cold Air Inductions Intake, Lingenfelter Axleback Phastek rear blackout kit
KNGTFALL
Drives: 2012 2SS 45th edition Join Date: Aug 2012
Sounds like the Green LED or driver is going bad.
Switch the connector to the halos at the module. If the problem moves to the other halo, then its the module. If it stays on the current halo its the RGB LED. It could also be the wiring between module and Halo, but this is a good start Last edited by GVA 45TH 2SS; 05-27-2017 at 04:21 PM. |
| Tags |
| camaro, halos, night, owl, problem |
