Old 05-27-2017, 09:24 AM   #1
N2O
N2O's Avatar
Drives: Camaro ZL1
MAF sensor cleaning?!
How often do you guys clean your MAF sensors? When i bought the car used i do not know when the MAF was last cleaned so any idea how often you guys do it?
Want to be sure that its reading correct.
2013 A6 Camaro ZL1
2.45 upper pulley/1 7/8 SW header/3inch SW catback/CAI intake/ID1050x injectors/Prometh DI methanol/
N2O is offline   Reply With Quote
Old 05-27-2017, 10:38 AM   #2
Crash76
Team 913
Drives: '14 ZL1, '15 Jeep GC, ‘22 Ram 2500
I do it every oil change... along with my blinker fluid inspection and headlight calibration.
Crash76 is offline   Reply With Quote
Old 05-27-2017, 12:10 PM   #3
chuckie669
chuckie669's Avatar
Drives: 2011 ss
I'd say probably once every few years. I have a dry filter on my cai, so I would imagine your fine unless running an oiled air filter. I say that as most people over oil those things.
chuckie669 is offline   Reply With Quote
Old 05-27-2017, 12:58 PM   #4
Olddudesrule
Resident nomad
Olddudesrule's Avatar
Drives: 2014 Summit White 1SS/1LE
I'd say Chuckie is spot on. Unless you're having issues, cleaning it every two or three years is fine. The wire in the sensor is very thin and make sure you only use cleaner specifically for MAF sensors. If you're running an oiled filter (I run an oiled Roto-Fab), use just enough oil to color the filter after cleaning, otherwise, like he mentioned, it can be drawn into the intake track and coat the sensor wire, fouling it....
Sold:
2007 Z06
2002 Viper GTS/ACR
2003 Z06
1965 FFR Cobra
2012 Nissan 370Z
ADM LSA Stage II, Roto-Fab CAI, Kooks LTH/HFC's, Phastek CC, ported TB, Mishimoto radiator and oil cooler, BC Racing ER Series CO's, JPSS 32mm Black Magic rear bar, JPSS front inserts, R1 Concepts Premier slotted rotors/Goodrich SS lines, Schroth ASM harness, MGW flatstick, Brey-Krause HB, Tuned by NicD, at Cordes Performance Racing.
Olddudesrule is offline   Reply With Quote
Old 05-29-2017, 07:54 PM   #5
ZL1-V
ZL1-V's Avatar
Drives: 2013 Camaro ZL1
From my off roading days regarding oiled filters
Olddudesrule was spot on about oiling the filter. You don't need a lot just enough as described. If you do think you sprayed too much oil, I have placed the filter in the upright position large opening down, and let the excess drain towards the bottom and wipe the excess off.
ZL1-V is offline   Reply With Quote
