Old 05-27-2017, 11:16 PM   #1
Caswell239
Caswell239's Avatar
Drives: 2011 2ss/rs
Hptuners. Fuel gauge level programming
I have a ctsv dual fuel pump and level sensor, and new fpcm. From lingenfelter. I'm trying to under the 4 programmable options in hptuners. If you have insight to what everything means please help.
My issue is my fuel gauge doesn't respond properly, first 1/4 is about 40 kms and then second is 100kms. I had this issue before and my then tuner tweaked it and fixed it much better. I reviewed my new tune vs old tune and the calibrations are very different. Compared to my friends tune that is zl1 pump and adm module, again very different. I remember a while back there was some posts about the calibrations that came with it were in correct.
Caswell239 is offline   Reply With Quote
Old 05-28-2017, 09:27 AM   #2
dreksnot
Served USN - Atomic Chimp
dreksnot's Avatar
Drives: 2021 Camaro ZL1 1LE A10 (stock)
Here you go.
> Past Builds: 2013 Twin-Turbo LSX434 M6 - 1,359rwhp daily
dreksnot is offline   Reply With Quote
Old 05-28-2017, 10:20 AM   #3
Caswell239
Caswell239's Avatar
Drives: 2011 2ss/rs
Thank you, now what exactly are those number tho? Gallons ? Or % or?
Old 05-28-2017, 11:01 AM   #4
dreksnot
dreksnot's Avatar
See the empty box to the right of the arithmetic signs (in green lettering)? "gal"
Old 06-10-2017, 04:40 PM   #5
Caswell239
Caswell239's Avatar
Drives: 2011 2ss/rs
Awesome thank you. Where did you get this info from?
