Old 05-28-2017, 07:57 AM   #1
iliassehk
Drives: camaro ss 2010
code p0171, p0174 , p0523 help
please help me guys what are this code mean ?
p0171,p0174,p0523
iliassehk is offline   Reply With Quote
Old 05-28-2017, 08:39 AM   #2
Avenging Orange
Avenging Orange's Avatar
Need a little more info....what have you done to your car?
The first are lean codes....the latter is oil pressure sensor I think.
https://youtu.be/9JD9it6SmB8
https://youtu.be/xmelTlEzI34
Old 05-28-2017, 08:41 AM   #3
bdd8401
Drives: 2015 2LT SW RS A6
Has the car been modified in any way like long tube headers or anything. P0171 is bank one sensor running lean, p0174 is bank two sensor running lean, p0523 is oil pressure sensor high input says it could be caused by a loose wire or a bad sensor or by running wrong engine oil. You can google the codes by typing the code by typing it in the google search bar example type in p0171 chevy. Sorry i can't be of more help but i am not a mechanic. Good luck i hope you get your car issue fixed so that you can drive and enjoy it.
bdd8401 is offline   Reply With Quote
Old 05-31-2017, 08:26 AM   #4
iliassehk
i change the exhaust ..
Old 05-31-2017, 10:13 AM   #5
frankwjr
frankwjr's Avatar
Drives: 2010 SS 2SS M6
need a tune....RDP dynoSteve best and most cost effective solution(IMHO)....especially considering your location....good luck...
Old 05-31-2017, 10:18 AM   #6
MrChrisLS3
Drives: 2018 1SS M6
https://www.obd-codes.com/p0171
https://www.obd-codes.com/p0174
https://www.obd-codes.com/p0523
Not sure what, exactly, you changed on your exhaust but if you did headers or high flow catalytic converters, there could be an issue with the electrical components, either not connected correctly or perhaps the wiring is getting burned on a pipe.
Also maybe an issue with PCV system causing high pressure in the crank case as well as causing the o2 sensors to read lean.
MrChrisLS3 is offline   Reply With Quote
Old 06-06-2017, 01:59 PM   #7
iliassehk
is there any issue with my car or just she showed this issue ? this dynosteve will fix the problem ? because i think the fuel consomption is little more higher than he was
sorry for my english
Old 06-06-2017, 04:02 PM   #8
Avenging Orange
We really need to know what specifically you changed on the exhaust. Did you install a catback system? Do you have headers? Did you remove or gut the cats?
Old 06-06-2017, 10:38 PM   #9
iliassehk
i change the thing in the middle with normanl tube and i change the rear exhaust
the old one was like that
http://www.camaro5.com/forums/attach...1&d=1367556617
Old 06-07-2017, 03:07 AM   #10
Avenging Orange
Cool. Sounds like we eliminated the exhaust.
Also might check check connections on 02's....and check plugs and wires....check intake connections on intake tube and clean your maf. Just trying to eliminate some simple causes.
Otherwise, find a dealer and get a proper diagnoses.
Old 06-09-2017, 10:09 AM   #11
iliassehk
so its not from the exauhst ?
Old 02-08-2019, 06:44 PM   #12
v8club
Drives: 2010 camaro ss
so what was the problem? I just got the same codes, p0174 and p0171
v8club is offline   Reply With Quote
Old 02-28-2019, 10:36 AM   #13
PepeLePew
PepeLePew's Avatar
Drives: 2010 2SS Coupe; 2011 2LT Vert
So many things can cause a lean condition. Anything from a vacuum leak to an exhaust leak to bad O2 sensor to clogged injectors or MAF needs cleaning. In my experience which is limited, I had a Chevy 5.3 with 100k miles that had a vacuum leak caused by a bad intake manifold gasket. I think the Ls3 and L99 has a much better intake manifold gasket than the gen 3 5.3L so that probably isnt your problem.
I'd do some clening and testing before you start replacing stuff. Others can help if I miss some things too...
1. Clean and test the MAF sensor.
2. Test fuel pressure.
a. If low or erratic, change the fuel filter first
b. If that doesn't help, pull the injectors and test them to see if they are clogged and give them a good cleaning or replace them if you don't get a good spray pattern.
3. Do a smoke test for vacuum leaks. If you see smoke, replace the bad gasket or hose.
4. If you put headers on or did anything to the exhaust pre cats, then look for excessive leaks (little leaks typically don't through codes). A bad exhaust manifold gasket will show signs of soot around the exhaust port. If you have non-GM gaskets, I recommend swapping them for OEM gaskets as they typically outperform cheaper ones that often come in lower cost Header kits.
5. Check the O2 sensors last if something above doesn't fix it. 99% of the time it wont be an O2 sensor if you aren't getting a fault code for an O2 sensor as well.
This can be a daunting task to fix these codes for sure. If you do the work yourself, there are a ton of youtube videos that will show you how to do each of these steps above without any specialized tools or expensive machines.
Good luck and let us know how it goes.
PepeLePew is offline   Reply With Quote
