Old 05-29-2017, 01:43 PM   #1
camarosspower
camarosspower's Avatar
Drives: 2010 camaro ss
Different coolants?
Hey guys shouldn't the coolant be the same color on the radiator and on the supercharger reservoir? I have the SLP tvs2300.
camarosspower is offline   Reply With Quote
Old 05-29-2017, 02:25 PM   #2
prod
prod's Avatar
Drives: HHR
Pretty sure thats normal. Dexcool vs regular antifreeze.
prod is offline   Reply With Quote
Old 05-29-2017, 02:57 PM   #3
camarosspower
Anything better to use for the supercharger other than regular coolant? The blower gets super hot right now here in texas
Old 05-29-2017, 10:23 PM   #4
prod
prod's Avatar
Drives: HHR
Are you able to monitor IAT2 on your setup? Have you verified the IC pump is running and coolant is flowing?
Old 05-29-2017, 11:13 PM   #5
camarosspower
I monitor the IAT's 1 from my aeroforce gauges that hook up to the obd port. Ic pump is working coolant is flowing. IAT's are reading 12x normal driving and go up to 140 on a pull.
Old 05-30-2017, 03:50 AM   #6
prod
prod's Avatar
Drives: HHR
Im no expert, but with texas temps that doesn't sound too bad. You could try flow testing the pump to make sure its in good shape as they can go bad, or upgrade to a stronger one. A water wetter might help a bit. I'm not sure if a phenolic spacer would help much, I dont see them discussed here much.
The most effective would be a meth kit if you are up for it.
Old 05-30-2017, 06:58 AM   #7
camarosspower
I'm already on meth
Old 05-30-2017, 12:08 PM   #8
BiggFoot
BiggFoot's Avatar
Drives: 2010 Camaro (M6) 1000+ HP SBE
I might be able to fix you up, but I need to make sure the guy buying my Maggie doesn't want the circulation cooler set-up.
When I switched to E85 I no longer needed meth injection so we converted my AIS Meth tank to a cooling water reservoir and switched the meth pump to a water pump, and added a return pump on the Maggie circulation outlet that sends the water back to the reservoir. My IAT's stay down all of the time except at a stop light they may climb to 115F only while I am sitting still.
You can also use this set up as a super-chiller when at the track by putting ice in it!!
Here are a couple of videos sort of explaining the set up.
F-1X, Cog Drive, ATI Super Pulley/Sprag ~ 19 psi
Blower Cam
Brodix BP BR 3 Heads
Kooks LT Headers and full 3" exhaust
Fore Triple Pump Fuel System with ID 1700X Injectors - E85 conversion
DSS 9” Conversion (1400 hp axles, driveshaft, pumpkin) & Strange 3.70 gears
McLeod RXT Twin HD Clutch & Upgraded Slave
RPM Level VII
TR6060
BMR Drag Suspension Package w/Strange shocks
Carlyle 15" and M/T ET Street R radials
10.1 @ 143 mph 1/4 mile
BiggFoot is offline   Reply With Quote
Old 05-30-2017, 12:11 PM   #9
BiggFoot
BiggFoot's Avatar
With this set-up you do away with the little cheezy reservoir that sits under the hot hood and basically use a 5 gal trunk mounted tank to replace it!
Blower Cam
RPM Level VII
TR6060
Old 05-30-2017, 07:16 PM   #10
Mr. Nasty
Emerald Coast Camaros
Mr. Nasty's Avatar
Drives: 2010 RS/SS Rally Yellow & 68 SS
Try Water wetter. That what I use for the Whipple. It seem to help.
Best @ 586/525 =10.41 @ 133
AS OF 12/13/14>633 RWHP =10.22@135
AS OF 1/31/15 @ 633 RWHP=10.16@135
AS OF 1/29/16 @ 633 RWHP=10.10@136
TOPED 700 PASSES AFTER F.I. AND STILL ON THE ORIGIANAL STOCK AXLE & DIFF
Mr. Nasty is offline   Reply With Quote
Old 05-30-2017, 09:06 PM   #11
camarosspower
So you're saying the ice box works better than meth? I already have the 5gallon tank in the trunk from alky
Old 05-30-2017, 09:06 PM   #12
camarosspower
How much water wetter do I add? How much did it help you.
Old 05-30-2017, 10:41 PM   #13
BiggFoot
BiggFoot's Avatar
I didn't say the water cooler works better than meth. They both have different functions. If you are still on 93 pump gas and running high psi (10+) then I would keep the meth for detonation/knock protection.
The guy buying my old Maggie needs the tank and pumps for his set up so it was all a moot point I suppose. I will say that if you ever switch to E85 then you probably wont need the meth injection anymore so at that time you could convert your meth tank to a water circulator, just keep that thought in your back pocket.
Blower Cam
RPM Level VII
TR6060
Old 05-30-2017, 11:15 PM   #14
camarosspower
Ok thanks. I really want the interchiller system but it makes no sense in wasting money on it if my plans are to go turbo
