Old 05-29-2017, 02:35 PM   #1
djsteveyoung
Drives: 2014 Camaro
2014 electric problem
Need some help. Anybody have problems with a crazy electrical glitch that effects the radio and the lights around the air and heat buttons ? The first problem was the tweeter on the driver side just went to white noise. Unplugged it, and problem went away. Then radio didn't start when the car did. just took 10 - 20 seconds. Then the lights in the air and heat control buttons began to blink 3 times,,, stop... blink 3 times... stop. This now goes on every other time I start the car. Nothing seems to connect any of the electric problems. It is possessed ! Dealer I took it to is scratching their head. Going back Tuesday 5/30 so they can really go over things. Has anybody had this happen to their 2014 ? Steve
djsteveyoung is offline   Reply With Quote
Old 05-29-2017, 02:40 PM   #2
18LTLoveIt
18LTLoveIt's Avatar
Drives: 2018 Hyper Blue LT RS
Sounds like you have a one off issue. Possessed, nah. Hope they can get to the bottom of it tomorrow. Good luck!
18LTLoveIt is offline   Reply With Quote
Old 05-29-2017, 02:44 PM   #3
redcoats1976
google exorcism...
Old 05-29-2017, 06:03 PM   #4
CamaroFred
CamaroFred's Avatar
Drives: Miss Con Ception
Christine
GTF out of the way!
2011 1SS/RS LS3 CGM
CamaroFred is offline   Reply With Quote
Old 05-29-2017, 07:32 PM   #5
swampcritter
Drives: 2014 Camaro LS / 13 zl1
I had the same types of issues with my 14LS . My lights for ac/heat would flash off and on.Then my radio started going out while driving and come back on a few minutes later.I ended up getting another radio off here and it fixed all the problems.
swampcritter is offline   Reply With Quote
Old 05-30-2017, 08:35 AM   #6
bdd8401
Drives: 2015 2LT SW RS A6
There was a tsb around that said if you have the issuses like you describe the radio and hvac system should be reflashed , do a search on here and google you should be able to find it. Take the tsb # to the dealer and they should be able to clear it up for you.
bdd8401 is offline   Reply With Quote
Old 05-30-2017, 10:40 AM   #7
InFiD3ViL
InFiD3ViL's Avatar
That is not going to help an alien abduction.
I'm certain that's what this is.
Old 05-30-2017, 02:50 PM   #8
JD555
JD555's Avatar
Drives: 2014 2SS RS, 6 sp man
the Tech SB said to reset the connections to the radio.
JD555 is offline   Reply With Quote
electrical issues
