Old 05-29-2017, 06:36 PM   #1
Rhino79
Rhino79's Avatar
Drives: 2010 Camaro SS L99/Auto
GPI cam/head/intake porting testing and results!!!!
Very detailed testing of different variants of our ss3 3 bolt cam, as well as our ported heads with and without CNC chamber work. We also tested our modded ls3 manifold 2 ways. And lastly tested against trick flow athedral fast 92 setup!!
http://www.gwatneyperformance.com/cam-testing
Rhino79 is offline   Reply With Quote
Old 05-29-2017, 06:55 PM   #2
Gunmetal Speedster
Gunmetal Speedster's Avatar
Drives: Savitar; The 500rwhp N/A Monster!
Great read guys! Feel free to send that timing cover my way
*SOLD*504HP/433TQ | Night Fury cammed • Cold Air Inductions intake • Bo White ported TB • Speed Engineering 1 7/8 longtubes • NPP catback • QTP low profile cutouts • Powerbond 25% UDP • 3.73 gears • JRE scoop • ZL1 grille • R1 Concepts drilled/slotted rotors • built/tuned by Weapon X Motorsports
Gunmetal Speedster is offline   Reply With Quote
Old 05-29-2017, 08:00 PM   #3
Bo White
Bo White's Avatar
There you go. Want answers you get answers.
2015 2SS 1LE Clutch reservoir, Vararam DRX, ported TB, TSP 2" headers, MGW shifter, stage 4 cam and Wilkes 11° 65cc heads
Totalled:
2010 1SS Wilkes Performance/Eagle 416 shortblock, TSP custom valvetrain, PRC 260 heads, Edelbrock Pro Flo 102, th400 swap, 8" PTC 5500 stall= 535/435 at the wheels tuned Gen 3 Performance and Dyno 10.97 @ 124 full weight in 3100 DA CamaroFest X
Old 05-29-2017, 08:04 PM   #4
Ashen 6.2
Ashen 6.2's Avatar
Drives: 2014 Camaro Z/SS
Great read!
Tuned by Ben @BWTuned, GPI 416 w/GPI S/C Cam, GPI Ported Heads, Holley Dominator ECU, Mag Heartbeat, ZL1 Fuel Pump/DSX Aux Pump, NW 103 TB, FIC 1650's, Alky Meth, Rossler T400 w/t-brake, Circle D Converter, Kooks Headers, Viking Coil Overs & all the BMR Goodies in the rear, Zl1 3.23 Diff, DSS Axles, Wiles Racing Driveshaft, Hendrix Offset Diff Bushings, AFE Solid Subframe Bushings, 875HP/843TQ 5FDP
Ashen 6.2 is offline   Reply With Quote
Old 05-29-2017, 08:17 PM   #5
2010reddevil
Drives: 2010 Camaro 2SS Victory Red 6M
Awesome read fellas. This is why these guys rock! Lots of great info there. Should help making some very educated guesswork pretty much fool proof.
2011 2SS 6A Red Jewel Metallic, Vararam Tune CAI, Magnaflow 3" Competition c/b, Speed Engineering 1-7/8 LT's, Circle D 5C, M/T 275/40R20 S/S, HPTuners tune by Ryan@GPI
12.3 @ 112 ACM as of 12/22/19
Gone on 12/28/19 R I P
2010 2SS 6M Victory Red/Black (old ride)
CAI intake, Speed Engineering 1 7/8" LT's, X4 base tune, Flowmaster Outlaw axle-back.
12.6 @ 115 SAR as of 9/19/15
Gone but never forgotten.
2010reddevil is offline   Reply With Quote
Old 05-29-2017, 08:28 PM   #6
Silver14
Drives: 2014 SIM 2SS
Excellent test and very well written article. Thank you for taking the time to do this.
Silver14 is offline   Reply With Quote
Old 05-29-2017, 10:42 PM   #7
BFASTNOTLAST
BFASTNOTLAST's Avatar
Drives: 2012 SS LS3
Nice work Ryan!
BFASTNOTLAST is offline   Reply With Quote
Old 05-29-2017, 11:46 PM   #8
CamaroDreams76
Tri-County Camaro SWFL
CamaroDreams76's Avatar
Drives: 2013 IOM 2SS/RS/1LE
So the ported IM vs just the rod mod picked up one hp?
Old 05-30-2017, 07:51 AM   #9
Rhino79
Rhino79's Avatar
Picked up alot under the curve, not alot at peak.
Old 05-30-2017, 08:59 AM   #10
lazerlemonta
lazerlemonta's Avatar
Drives: 2010 C6 1LT
Thanks for all the reslutls! I'd like to see a cam peek closer to 7k to pull gears at 7500 when I finally decide to pull the trigger.
2010 C6 JET STREAM BLUE
BOLT ONS TO THE EXTREME, GPI 281cc HEADS, Darth_V8r SPEC CAM, FAST 102 INTAKE, CRANK SCRAPER, QUARTER MASTER 7.25" CLUTCH, RPM 3.90 STAGE II DIF, Z51 Gear Set AND E85
Best ET 10.58 @ 131.8 stock heads and stock cam 453/445 SAE
10.62@134.82 GPI 281CC Heads, SS4 Cam and X1 Intake
Best 1/8 6.80@105.75
Best MPH 134.82
lazerlemonta is offline   Reply With Quote
Old 05-30-2017, 09:01 AM   #11
BFASTNOTLAST
Drives: 2012 SS LS3
Solid roller and call it a day. GPI has them figured out too!
Old 05-30-2017, 09:08 AM   #12
BFASTNOTLAST
Drives: 2012 SS LS3
FWIW my current Hyd. GPI cam makes peak pwr at 6600-6700 ish and carries it out nicely without a big fall. starts making 500HP at 5800 and still makes 500 at 7200-7300....
Old 05-30-2017, 09:19 AM   #13
Rhino79
Rhino79's Avatar
Problem isnt the hyd cam, its the intake. Go with a shorter runner manifold and we can do that with a solid or hyd setup.
Old 05-30-2017, 10:06 AM   #14
HioSSilver
Drives: 99 camaro ss with a bolt on ls6
What's up rhino?!
Nice test man
HioSSilver is offline   Reply With Quote
