Old 06-03-2017, 03:55 PM   #1
LCPLPunk
USA-1
LCPLPunk's Avatar
Drives: 2010 Camaro SS L99
Need some help, car died!
Hey guys,
I need some help! My 2010 Camaro SS L99 has had it's 'Service Stabiltrak' light come on and it's running rough. I started it a few minutes ago and it ran for about 30 seconds and then died. I also have a strong fuel smell. I have a code reader and the codes that pop up are:
P0205 - injector circuit malfunction
P0305 - Misfire cylinder 5
I have done the following:
1. replaced the spark plug in cylinder 5
2. swapped the injector coil from another cylinder to cylinder 5 (codes stayed the same)
3. listened to the injector - sounded like it was clicking like another one, but hard to tell since the engine was chugging
4. The spark plug wire looks like all the others, but I haven't replaced/tested it
Should I buy all new spark plug wires?
I'm contemplating replacing the injector, but no one here in Hawaii sells OEM stuff, only knock off (GP Sorensen, etc). I'd like to get the car running ASAP, so if I get impatient I might just grab one of the knock offs.
Any other ideas?
My car has 58k miles.
"A Camaro in the garage is safe, but that's not what Camaros are built for..."
R2C CAI / Apex Scoop / VMAX Ported TB / Speed Engineering LTHs / X-pipe / GPI port/rod-mod intake manifold / Circle D 3200 278mm Converter / 3.91 gears / DynoSteve tuned / 1LE Shocks/Struts/Toe Links / ZL1 Rear Sway Bar / Z/28 Trailing arms / Prothane Radius Arm & Subframe Bushings / BMR UCA Bracket, Steering rack bushing / B&M Tranny Cooler / RX Catch Can / Jannetty Tranny Dipstick / 2012+ Heater Hose / 2013+ Rearview Mirror / Fuel rail flip / Drake shifter / Oil Cooler Delete
LCPLPunk is offline   Reply With Quote
Old 06-03-2017, 04:06 PM   #2
CFD
Drives: 2SS/RS L99 BLACK
Sounds like the#5 injector might be stuck open or malfunctioning, with the smell of fuel I'm thinking stuck open. When you pulled the plug was it wet?
CFD is offline   Reply With Quote
Old 06-03-2017, 04:13 PM   #3
LCPLPunk
USA-1
LCPLPunk's Avatar
It was a little bit, yep. Since I did seem to hear it clicking though does that mean it could still be stuck open (I'm not super knowledgeable on injector operation)?
Old 06-03-2017, 04:28 PM   #4
CFD
If the plug is wet there's a good chance it may be stuck open or dirty/worn so it's not closing all the way. There's a couple of things you can do to check it without any special tools etc. but where as you are working with fuel you must take caution and work with a cold motor. You can take the fuel rail off with the injectors still attached, making sure you are aiming them in a way that spraying fuel will be capture in a container or rag and have someone turn the key on, if it's stuck open it will spray like crazy, if it's dirty or not seating all the way it may have a slight drip or the tip may get a little wet with fuel. You can also swap it with a different injector from a different cylinder and see if the problem follows it. Just use caution when working with fuel. Here is a quick video of one that was stuck open in my car.
Old 06-03-2017, 04:38 PM   #5
LCPLPunk
USA-1
LCPLPunk's Avatar
Oh, wow, so in this video the car wasn't even on? You just turned the key to the 'on' position?
For this test did you fully remove the fuel rail (to include disconnecting it from the fuel line) and then reconnect the fuel line back to the car and then test it?
Old 06-03-2017, 05:02 PM   #6
CFD
You do not start the car. Keep all the injectors in place and all the fuel lines attached or the system will not build pressure. Have someone turn the key on so they can turn it off while you watch the injectors. Because the system is under pressure if the injector is hung open or not seating right it will keep spraying until all pressure is relieved even after the key is off. If it's not hung open and just a small leak the tip may show a slight sign of wetness, it could be very minimal depending on how bad, wipe the tip off and if it gets wet again it's junk. If this test doesn't show results there is a black cap on the end of the fuel rail, remove it and there is a small valve, similar to the ones on your wheels, depress it like you were letting air out of your tire and it will relieve the pressure in the system, then swap the #5 injector with one from a different cylinder, preferably on the opposite side, re-install everything and start the car, if the problem follows the injector it's junk if not there is a good chance the injector are not the problem.
Old 06-03-2017, 05:09 PM   #7
Kajun
Kajun's Avatar
Drives: 2013 1SS L99
Try to borrow a noid light. If it flashes while car is running replace #5 injector. If it's on steady or off you will have a circuit or PCM problem.
2013 1SS/RS L99-GPI VVT SS1 - TSP 1 7/8 headers with Borla Touring exhaust - ESS Tuning YSI V7 - Fore Innovations Dual pump fuel system - 1" BMR lowering springs - BMR toe rods and trailing arms - Prothane rear cradle bushings - Yank 3400 Stall -
Kajun is offline   Reply With Quote
Old 06-03-2017, 06:37 PM   #8
LCPLPunk
USA-1
LCPLPunk's Avatar
UPDATE: I went ahead and replaced the injector at cylinder 5 and the car is running normal again! I drove it around for about 5 minutes and didn't feel any lugging/chugging, etc. I have my fingers crossed though because we all know how car stuff goes...
Old 06-03-2017, 07:20 PM   #9
CFD
Cool, sounds like you've got it.
Old 06-03-2017, 07:27 PM   #10
LCPLPunk
USA-1
LCPLPunk's Avatar
Thanks for the help man!
Old 06-03-2017, 07:47 PM   #11
CFD
Glad to help if I can.
Old 08-16-2017, 01:27 AM   #12
LCPLPunk
USA-1
LCPLPunk's Avatar
So...the issue reared it's ugly head again. I replaced the injector in early June and the car has run great since then, but last week it started giving my troubles. I've got the same codes as last time... :(
Old 08-16-2017, 01:52 PM   #13
Mando2776
Mando2776's Avatar
Drives: 2013 Camaro 2SS/RS
Same injector?
Mando2776 is offline   Reply With Quote
Old 08-16-2017, 01:55 PM   #14
LCPLPunk
USA-1
LCPLPunk's Avatar
The replacement I used was a brand new one from GP Sorensen. It's entirely possible, but I feel like it isn't the injector since it's only two months old.
