![]() Drives: 2013-ZL1, 69-Z28, 71-CHEVELLE SS Join Date: Oct 2016
Can I safely drive 1 hr to a shop to get a tune???
Im torn between email tune or dyno tune?
Now I am thinking about going to a shop and get a Dyno tune and includes a street tune also. The shop is about 1 hr away. Can I drive it there without problems if I take it easy? I have ID 850's (These are the only mod not installed yet, the shop will install them when I get there) Already installed 9.55 lower pulley Cai (Cold Air Inductions) Afco cooler Roto fab ic resevoir TR71X Plugs Catch can Lt headers Hiflow cats Bap Thanks
2017 C7 Z06
2013-ZL1 2017 HELLCAT SOLD 2019 HELLCAT REDEYE WB 69-Z28, LSA SWAP, T56 MAGNUM 71-CHEVELLE SS, 496 STROKER TH400 Last edited by BEECHFRONT; 06-04-2017 at 04:16 PM. |
![]() Drives: 2015 ZL1, Red Hot A6 Join Date: Aug 2016
Which cai is it? If it's a rotofab you should be fine as long as you stay out of boost but other intakes may skew the maf more, I haven't dealt with others on this platform.
2015 Red Hot ZL1, Rotofab, Kooks LT's, 10" lower, ID850's, JMS BAP, BTR stage 3 torque cam, meth injection, self tuned with HPtuners
1969 Chevelle, 418 LS3, Ridetech suspension |
Cold Air Inductions cai (updated post)
2017 C7 Z06
2013-ZL1 2017 HELLCAT SOLD 2019 HELLCAT REDEYE WB 69-Z28, LSA SWAP, T56 MAGNUM 71-CHEVELLE SS, 496 STROKER TH400 |
KaBoom1701
Ask the shop for a basic tune and then they can dial it in when the car arrives.
Once you change your injectors you have to tune the car. Or just bite the bullet and get a flat bed tow truck to deliver the car.
Mods:
#5 | |
I know I need a tune after installing the 850's in order for it to start and run,thats why I am having them install them at there shop They dont do email tunes for handhelds, I think they just flash the pcm. Trying to avoid a hefty towing bill or else I would have installed the injectors and had it towed.
2017 C7 Z06
#6 |
Team 913
Drives: '14 ZL1, '15 Jeep GC, ‘22 Ram 2500 Join Date: Apr 2015
If you get into some boost you will run the risk of leaning out due to lack of fuel...
Can you safely drive to the shop? No ... Can you risk driving it to the shop without damaging your car? Yes You are going to throw cel codes for the LTs I maxed the duty cycle of stock injectors with a 5% pulley and cai ... you are running a 22% |
#7 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 02 Z06, 95 Trans Am, 2012 ZL1 Join Date: Mar 2012
If you just drive normal and not get on it you'll be fine.
#8 |
ZL1 Pilot
Take the blower belt off and drive it. For added protection against undesired boost
#9 |
Just keep your foot out of it. You'll be fine.
#10 |
![]() ![]() Drives: 2014 Camaro SS/RS 1LE 1967 Camaro Join Date: Oct 2013
Bryan is right. just drive like a very casual driver and all will be good. If you you get stupid with it expect stupid thinks to happen
#11 |
Thanks for the feedback guy's, kinda figured I would have to drive like a old lady and stay out of the boost just wanted to make sure.
2017 C7 Z06
#12 |
![]() Drives: 2015 ZL1 Join Date: May 2015
Can your tuner put a base tune on your pcm if you send it in to him?
That's what I ended up doing. |
