06-05-2017, 10:09 PM | #1 |
Drives: 2015 Z/28, 2015 1LE Join Date: Feb 2017
NPP exhaust
Tried searching a little on here, came up with nothing. But was under the car the other day and noticed that the NPP has an H-pipe under there. Was wondering how much improvement it would gain by cutting that out and putting an X-pipe under there.
Improvement as far as sound and gains Thanks |
06-06-2017, 11:02 AM | #2 |
Drives: 2015 Summit White 2SS/RS 1LE Join Date: Nov 2014
I have no idea on performance, but i'm sure it would be minimal at best.
After I installed my high flow cats, I had a horrible noise from the NPP. I did EVERYTHING possible to diagnose the noise. There was no rattle, hangers were fine, NPP butterfly valves werent rattling, and I even cut open the mufflers to see if any baffles had broken...they were all fine. It was loud enough to be embarrassing to drive, so I picked up a 3" Magnaflow catback. It's not as loud, but the noise is gone. The Magnaflow has the X pipe. After more research, I found a lot of info on "H pipe rasp" which sounds like a rattle. I have the NPP in my barn, and I might weld in an X pipe just to see what happens. |
06-06-2017, 12:36 PM | #3 |
There are multiple threads on this, like andoskyy said it would be very minimal if any gain, it'll just change the exhaust note
Sent from my Pixel using Tapatalk
12.3 @113MPH - Full Bolt-Ons w/ Nitto 555r on 18" wheel
06-07-2017, 09:40 AM | #4 |
Ok Interesting, I figured it would be very minimal but wanted to double check. That is good to know about going wth high flow cats and that rattle though.
Thanks guys |
06-07-2017, 09:45 AM | #5 | |
06-07-2017, 10:04 AM | #6 |
Drives: 2012 ZL1 - #670 Join Date: Jun 2009
Running Solo HF cats here, and never had a problem. Is it loud, yes but not header loud and only gets loud when you put your foot in it.
08-13-2017, 11:17 AM | #7 | |
Drives: 2014 2SS MT, Convertible Join Date: Jun 2015
Steve
2014 2SS MT, Convertible Saint Augustine FL |
08-13-2017, 11:20 AM | #8 |
