Old 06-06-2017, 09:18 PM   #1
DaddySS
Kept The Faith
DaddySS's Avatar
Drives: 2011 Camaro SS Convertible
Convertible top 5th bow replaced
I finally took the plunge – removed the top, replaced the 5th bow and brackets, and did the rubbing modifications per the TSB. GM Customer Service was no help – after multiple communications all I got was “the car only has 8,000 miles but it is past warranty in years”. I had hoped Chevy would stand behind their product a bit more considering the top issues and being a long time Chevy customer (first car was a ’64 Impala SS convertible with a Muncie 4 spd) but no luck.
The Parts per #PIC5449D: Convertible Roof Cloth Sags At Rear / Large Gap Between Number 5 Bow And Rear Panel - (Nov 4, 2015) Total parts were about $500.
Part Number Description QTY
22856131 Folding Top Pivot Bracket - LH 1
22856132 Folding Top Pivot Bracket - RH 1
22936377 5th bow / bracket assembly 1
11611499 Pin 8
19120405 Clip 8
11546538 Rivet 4
I had asked on the forum how to get the correct 5th bow and the answer is if you order the bow, the part was revised in the system – same part number and you’ll get the right part.
And thanks to DanielW and Angie11 for their complete write ups – a huge help (and inspiration).
The Patient:
The Problem:
Part of the cause:
Water bag too tight in the corners
The repair:
Whether you’re doing just the brackets or the full repair, order a couple of clips for the High mounted brake light – they don’t stock them online and it takes about two weeks.
The progress:
Note that I taped cardboard across the trunk in case the top got too close during the removal.
Note how the old bracket on the left hits is touching the cardboard, ahile the new bracket on the right is an inch or more higher – that’s how bent the bracket was.
Note also the blue plastic interior trim tools, if you don’t have a set get them, invaluable for all trim work. Eastwood has an inexpensive set – I’ve had mine for years.
Final prep:
I cleaned and coated the top with the Raggtop kit. I like to mask the car. Only takes 30 minutes and saves a lot of cleanup after.
The result
2011 Vert - 2SS/RS 6spd Triple Black
DaddySS is offline   Reply With Quote
Old 06-06-2017, 10:06 PM   #2
Royal Tiger
Drives: 2013 2SS/RS Convertible
Great write up!!!
I too have my Chevy (non)Customer Service story. Real shame.
Hopefully my top stays perfect.
Royal Tiger is offline   Reply With Quote
Old 06-06-2017, 10:20 PM   #3
oldschoolkat
oldschoolkat's Avatar
Drives: 2013 SS Camaro
Thx 4 sharing .... hoping I don't run into this issue
Sent from my SM-N920P using Tapatalk
oldschoolkat is offline   Reply With Quote
Old 06-07-2017, 07:09 PM   #4
DaddySS
Kept The Faith
DaddySS's Avatar
The enhancements in the "13 should keep you from the trouble, I advise to always stop halfway down and check how the top is folding, and clearing the water management bag.
Old 06-07-2017, 10:51 PM   #5
sbubbaklein
sbubbaklein's Avatar
Drives: early 2011 Camaro convertible
great job
Early 2011 LT Convertible, ZL1 bumper, hood, side skirts, belly pan and wheels, Truecarbon ECF hood extractor, K&N CAI, Elite catch can, Big Worm Bow Tie emblems, Jacfab bracket, Vitesse TC, BMR strut brace, BMR tunnel brace, NPP exhaust
sbubbaklein is offline   Reply With Quote
Old 06-08-2017, 07:48 AM   #6
Deputy347k9
Deputy347k9's Avatar
Drives: 2014 Ashen Gray Convertible
A wonderful job done and many thanks for the great pictures, give a greater understanding. I have a 2014 convertible and pray I never have to do this but if I do it's from owners such as yourself that has made the job much clearer, especially with all the part numbers as well as the small tidbits such as ordering a couple of clips for the high mounted brake light! Not fun when you have the car torn apart and learn that you need two little clips and they are not in stock! Again, thank you and a job well done. Even though it was a pain in your backside look at what you have learnt and accomplished! You might even be able to teach some of the so called techs on what to do and how to properly do it! Larry
Deputy347k9 is offline   Reply With Quote
Old 06-08-2017, 01:47 PM   #7
buffetfn1
Drives: 13 Panther, 12 ZL1, 11 IPC
Thanks for the informative post! Fingers crossed they have it right on my 13
buffetfn1 is offline   Reply With Quote
Old 06-08-2017, 07:34 PM   #8
DaddySS
Kept The Faith
DaddySS's Avatar
Thanks all for the kind comments. The job was more stressful and time consuming than difficult. The time consuming part is taking care not to break clips or parts, figuring where to pry on what and where to start on some of the pieces.
Another hint is spend the $25 on good heavy duty rivet tool if you're going to use the GM rivets.
Those of you with '13 and up tops have the revise water management system, revised bow and pivots so you should have no worries. I still say take care with the top when lowering. Properly cared for the 11's and 12's should be OK too - mine was bent when I bought it.
Old 06-08-2017, 08:30 PM   #9
95birdible
95birdible's Avatar
Drives: 2012 1SS Camaro Convertible
From all my experiences with my first 2012 built on 7/26/11 and my buyback car built on 4/9/12, the differences are night and day with the top and bag. Per Jack Pantaleo the former brand manager, Mary Barra, and many others in Corporate GM who I was emailing and talking with, the changes to the bow and bag were put on the line in February of 2012. The top with cords was revised for the 2013 model year to pull it tighter. If you have a 2012 with a build after February, you should be good if you maintain it properly and do not abuse your top.
2012 1SS Crystal Red Convertible
"Cherry Bomb"
Winner of the #NameThatCamaro Spring Special Edition
"Green Flash"
95birdible is offline   Reply With Quote
Old 05-13-2020, 12:50 PM   #10
JimB3028
Drives: 2012 Camaro Convertible RS
REpair
Did you have to make any adjustment to the water bag to prevent this from happening again?
JimB3028 is offline   Reply With Quote
Old 07-20-2021, 11:52 AM   #11
Chodaboy
Chodaboy's Avatar
Drives: 2011 V6 rag top
Anyone know where I can source one of these in the UK? Or possibly just buy the brackets from the US without the bow. Shipping cost for the entire bow to the UK is ridiculous.
Chodaboy is offline   Reply With Quote
Old 07-20-2021, 07:20 PM   #12
Whoomba
Drives: 2024 Camaro 2SS CE Convertible
Mines a 14 and only minor issues. It’s stuck twice but I blame that on it being cold and water in the back floor a few times. Never resolved that.
Whoomba is offline   Reply With Quote
Old 08-24-2022, 12:28 PM   #13
slphawk
Drives: 2011 Camaro SS Conv. 1994 Firehawk
Bow question
On a 2011 do you need to replace the bow or can you just replace the brackets, pins and retainers? The bow now cost $400. The rest of the parts just cost me $470.55.
Thanks, Jim.
slphawk is offline   Reply With Quote
