![]() Drives: 2010 Camaro 2SS/RS Join Date: Mar 2017
Help making my idle louder
Hey all,
So i just bought a borla atak axleback and it sounds great under WOT, especially when you're cruising and the RPMs drop below 3k there's a very satisfying crackle. However, I'm very unimpressed with the sound at idle, can barely appreciate it. My friend with a 6cyl charger and flowmastwr 40 axleback a gas a much meaner and fuller sound at idle, and he paid less than I did for his exhaust! Anyone have any tips or next steps I can take? |
![]() ![]() ![]() Drives: 2014 BRM 1SS/RS Join Date: Sep 2011
Go long tube and catless!! Then get a good tune afterwards!!
2014 Blue Ray Metallic 1SS/RS A Road Warrior |
![]() ![]() ![]() Drives: 2010 2SS/RS LS3 A6 IOM Join Date: May 2013
LTs are a noticable sound improvement, especially when you get into it. Cams can make a big difference too.
I just wonder why it's so quiet, I thought the ATAK was the loudest exhaust available for the camaro. Is it possible to install long tube headers with an axleback? I thought you needed a full system for that
Yes, LTs w/hi flow cats will match up with the factory pipes. I went that way until the Stainless Works 3" retro chamber exhaust was installed. Now that the SS is cammed, the exhaust needs to be toned down a bit.
#6 |
Drives: 2011 2SS/ RS INFERNO ORANGE L99 Join Date: Dec 2012
Have you stock resonaters cut out and have a Magnaflow tru x pipe installed. No you dont need the whole system for long tubes.
#7 | ||
#8 | |
"BEASTM*DE"
Vengeance Racing Stage 1 Kit 575rwhp, 569 rwtq...
Rims powder coated gloss black...BFG'S Comp 2 A/S... Dual 10" Kicker Comp S Subs 1200w... |
#9 | ||
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '17 Corvette Grand Sport M7 Join Date: May 2012
I must sound like a broken record on here but, get high-flow cats ASAP! I can't stress it enough. The stock cats put a strangle hold on the exhaust.
Here is my car (1st vid-with stock manifolds, high-flow cats and Flowmaster mufflers. 2nd vid-with BBK shorties installed):
MY RIDE: 2017 CORVETTE GRAND SPORT--TRIPLE BLACK, 7 SPEED MANUAL, VARARAM TCR-7 INTAKE, BORLA CATLESS X-PIPE, CARBON FIBER STAGE 2 AERO, MGW SHORT-THROW SHIFTER
**SOLD**2011 TRIPLE BLACK SS CONVERTIBLE--6 SPEED MANUAL, MANY MODS, 455 RWHP/435 RWTQ DAD'S RIDE: 2012 ZL1 #1866--BLACK, 6 SPEED MANUAL, EXPOSED CF HOOD, POLISHED WHEELS, SUNROOF, ROTO-FAB INTAKE "Silly Americans, taking from the rich and giving to the poor only works in fairy tales. Success is earned here!". Last edited by DRKS1D3; 06-08-2017 at 05:58 AM. |
#10 |
Started#gottalovethatblue
DRKS1D3 beat me to it. High flow cats are a quick win. The factory cats are the biggest choke point on the factory exhaust. IF you are planning on going with headers later and you want long tube headers, they will make a significant difference in the idle sound. The other option would be exhaust cut outs or diverters. However, with the factory cats it will still idle somewhat quietly. When I was installing my catback I had to hear what the car sounded like without anything past the factory cats and it was surprisingly quiet for no mufflers. Don't get me wrong, it was much louder, but it was not as loud as I thought it would be. My long tube headers with cats and my catback is louder than shorty headers out factory cats and nothing else.
#11 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Inferno Orange 2SS/RS Join Date: Apr 2010
Start with the x-pipe first.
Your stock exhaust is great....flows pretty good. I would wait on the hi-flo cats till you decide if you want headers (which will require a tune). I say this because when you get headers....everyrhing changes and the hi-flo's you would buy now wont bolt up to the headers...so you'll end up wasting money. The other issue is when you remove too many parts of your exhaust before the headers...you'll end up with one hell of a noisy/droning exhaust you may not like. Rule of thumb here....exhaust starts at the front.
Avenging Orange: 43 years of not buying into the Hype........and damn proud of it!! https://youtu.be/9JD9it6SmB8 https://youtu.be/xmelTlEzI34 KICKING CANCERS ASS SINCE 2015!! |
#12 |
Will HF cats cause any issues with emissions or codes? I'm assuming that they're still fully functional cats....right?
#13 |
CAR-DASHIAN
Drives: 2015 Ashen Gray Metallic 2SS/RS L99 Join Date: Nov 2015
I have a set of JBA 2 2/1" inlet and outlet (stock exhaust connections) for sale. They have about 5K miles on them. They even have the rear O2s connected.
Should not throw a code. These with a CAI might throw one, but O2 extender plug-ins are like $5 and will keep that from happening. $200 plus the ride.
PERFORMANCE: ColdAirInductions CAI, ADM Race Scoop, Cordes Performance Racing Ported TB/IM/Custom VVT Cam, WFO Milled Heads, Stainless Power 1 7/8" LT/3" HFCs, JBA 3" Comp. Cat-Back, Taylor 10.4mm Plug Wires, Tim King Performance Stage 3 6L80, Circle D Billet 3600 Stall, Nic D ECM/TCM Tune, - 458rwhp/413rwtq (prior to PIM), Forgestar F14 (F)18" / (R)17" Rims.
SUSPENSION: Z/28 Rear UCA Bushings, Carlyle Racing LCA/TA, BMR Adj. Toe Rods/Xtreme Anti-Roll Bar, Justice Pete Castor Locks/Radius Rod Inserts, Pegasus Billet Rear Cradle Bushings, Mickey Thompson Street SS II 305/45/17 tires. |
#14 | |
**SOLD**2011 TRIPLE BLACK SS CONVERTIBLE--6 SPEED MANUAL, MANY MODS, 455 RWHP/435 RWTQ DAD'S RIDE: 2012 ZL1 #1866--BLACK, 6 SPEED MANUAL, EXPOSED CF HOOD, POLISHED WHEELS, SUNROOF, ROTO-FAB INTAKE "Silly Americans, taking from the rich and giving to the poor only works in fairy tales. Success is earned here!". |
