Old 06-08-2017, 11:15 PM   #1
StlRomAniaN
StlRomAniaN's Avatar
Drives: IOM 2010 Camaro 2SS/RS
Coilover Top Mount Movement
This is normal while turning the wheels, correct? Any type of grease needed to aid the movement? I'm just wanting to make sure everything is good as is.
https://youtu.be/HJn14kh4ub0
Oh! And feel free to let me know what aftermarket 12mm endlinks you prefer and why. Thank you!
StlRomAniaN is offline   Reply With Quote
Old 06-09-2017, 07:42 AM   #2
1Coopgt
1Coopgt's Avatar
Drives: All Black 2012 1LS
Yup from my understanding of all the reading I've done on this forum . That movement is normal.
Mods, K&N CAI ,VTC , GM Perf Axleback Exhaust, Elite Eng CC and CSS, GM Strut Tower Brace,Carbon Fiber Anvil Spoiler,ASC T5 Splitter,Gen5diy Foglight kit.
1Coopgt is offline   Reply With Quote
Old 06-09-2017, 08:12 AM   #3
StlRomAniaN
Thank you for following along with my threads. You've been helpful.
Old 06-09-2017, 08:15 AM   #4
Black_SS10
SomeguyK
Black_SS10's Avatar
Drives: 2010 Black 2SS/RS
Yup its normal. Those rubber upper mounts can get worn and become noisy over time.
More to come.
Black_SS10 is offline   Reply With Quote
Old 06-09-2017, 08:17 AM   #5
JusticePete
Drives: Camaro Justice
What is the clunk we hear?
Old 06-09-2017, 08:20 AM   #6
JusticePete
JPSS OEM Quiet High Efficiency Adjustable Endlinks
These links are exceptionally high quality and you can feel it as soon as you get your hands on them. The ball joints are virtually perfect. Rotate the stud and ball. You can feel the precision. We believe our endlinks offer the race track ready performance of a spherical style endlink with a greater range of motions and are as quiet as the endlinks installed at the factory.
http://www.jpssonline.com/#/jpss-oem-quiet-endlinks/
JPSS OEM Quiet High Efficiency Adjustable Endlinks are adjustable in length, a feature that is critical in corner weighting your performance vehicle.
Old 06-09-2017, 08:25 AM   #7
StlRomAniaN
The phone was set on my car so the loud clunk is over exaggerated. It's just the rubber mounting going flat once the wheel centers. The other sounds is the coilover turning and the rubber mounting underneath rubbing against the top mount inside the wheel well.
Old 06-09-2017, 08:27 AM   #8
StlRomAniaN
I've seen some endlinks that are thicker. I'm not saying that it's better to have a thicker endlink, but I'm just curious as to why these are similar to OEM thickness. I know all of the action is at those spherical ends.
Old 06-09-2017, 08:46 AM   #9
JusticePete
There should be no clunk in the articulation of a 5th Gen strut mount.
There should be no noise at all, no squeaks, no clunks when the wheels are turns and the car is not moving. This is the case on a new mount or a 150,000 mile mount.
Something is not right.
There are lots of hard miles on this Camaro, roughly the same as yours if I remember correctly.
Old 06-09-2017, 08:58 AM   #10
StlRomAniaN
The clunk is not audible to the ear. It was only heard because of the sensitive mic of my iPhone and the iPhone being on the car.
Old 06-09-2017, 09:00 AM   #11
StlRomAniaN
I don't know what could be wrong though. I posted pictures of the rubber underneath the strut tower. Looks a bit worn, but that's it.
Old 06-09-2017, 09:08 AM   #12
JusticePete
And the squeaking?
Post the picture again.
Old 06-09-2017, 09:12 AM   #13
StlRomAniaN
And the squeaking?
Oops. I guess I didn't post them. Here you go.
Old 06-09-2017, 09:41 AM   #14
JusticePete
Thicker doesn't necessarily mean better
