Old 06-09-2017, 05:54 PM   #1
Mike J
Mike J's Avatar
Drives: 2015 Topless Btch RS
Tonneau cover which one is this?
I found this one for sale, is this the one that has the problem of flying off at 60mph..I believe it came off a 2012.
Thanks
Mike J is offline   Reply With Quote
Old 06-09-2017, 06:50 PM   #2
Fireman124
Drives: 45th convertible ss
That is the second generation cover. There should be two button like retainers that the two nylon bungies would hook onto.
Fireman124 is offline   Reply With Quote
Old 06-09-2017, 07:10 PM   #3
Mike J
Mike J's Avatar
Thanks Fireman. .the 2 buttons that you talk about are possibly what my wind restrictor is attached to?
Old 06-10-2017, 12:17 AM   #4
Bowtie-Bri
Bowtie-Bri's Avatar
Drives: 2013 Camaro 2SS RS Convt.
I have that style on my 13.
2013 Nickey Stage II Camaro SS Convertible #10.Black w/ Red leather interior. No Weeds Elec. Diverters, CNC ported heads, custom grind cam, upgraded fuel injectors, ZL-1 fuel pump, V-Max ported TB, Red Magnuson Super Charger with rear cog drive, upgraded rear axles good for 1400Hp, 3:45 gears, Tremec 6 spd., Pedders adj. coil overs, Phadt ZL-spec swaybars, 800Hp at the crank, 670RWHP, 613ft.lbs. torq. @ 11lbs. boost. SOLD!!!
Bowtie-Bri is offline   Reply With Quote
Old 06-10-2017, 02:00 PM   #5
18LTLoveIt
18LTLoveIt's Avatar
Drives: 2018 Hyper Blue LT RS
no when top is down you can feel/see nubs.
18LTLoveIt is offline   Reply With Quote
Old 06-12-2017, 04:19 AM   #6
Mike J
Mike J's Avatar
Thanks for the info guys
Old 06-12-2017, 04:52 PM   #7
Stewart
Stewart's Avatar
Drives: 2014 Camaro 2SS RS & Ground effects
If your wind restrictor is like mine, it attaches between the back of the body and the pins. This leaves the pins available to hook the cover to. That is the style cover that came with my 2014, in which has never come off at any speed.
Don’t walk in front of me, I may not follow; Don’t walk behind me, I may not lead; Walk beside me, and just be my friend.
MY BUILD LINK: http://www.camaro5.com/forums/showthread.php?t=484260
Stewart is offline   Reply With Quote
Old 06-12-2017, 08:10 PM   #8
oldschoolkat
oldschoolkat's Avatar
Drives: 2013 SS Camaro
That's the good one...been over 100 mph with no issues
Sent from my SM-N920P using Tapatalk
oldschoolkat is offline   Reply With Quote
Old 06-13-2017, 08:14 PM   #9
Mike J
Mike J's Avatar
Perfect...thanks guys
