![]() Drives: 2013 ss2 vert l99 Join Date: Apr 2017
2013 fuel tank trap door...bad idea
So after searching forums I decided to switch out my fuel pump by cutting a trap door rather than dropping the fuel tank..
Needless to say the plastic fuel tank butts directly against the metal underbody of the car and not cutting through in to the fuel tank was pretty much unavoidable, including wiring that was sandwiched between the tank and the metal with zero space.. The cuts were filled, the wiring repaired and the zl1 fuel pump was installed, all is well but, do yourself a favor and don't attempt this route when changing fuel pumps... at least on a 2013 vert ss. |
![]() Drives: 2014 Camaro 2SS 1LE Join Date: Jul 2015
If you don't know what u doing or have tools for job-you should stay away from job like this
![]() ![]() ![]() Drives: 2011 2SS Convertible Supercharged Join Date: Nov 2010
It's not that hard with the right tools.
![]() Drives: 2010 Camaro 2SS M6 - Intake/Exhaust Join Date: Sep 2014
Alot depends on where you decide to cut. I used a nibbler (electric metal cutting shears), which prevented me from cutting into the tank (lower jaw rode on top of tank).
![]() ![]() Drives: T Join Date: Mar 2015
I used a cutting wheel off a compressor ,about 10 minutes of precise cutting, not a problem on my end.
#6 |
![]() ![]() ![]() Drives: Z06 wannabe Join Date: Feb 2015
I dropped the cradle.....it was pretty straight forward.
Apex Focused
#7 |
![]() Drives: 2013 Camaro 2SS "Diablo" Join Date: Jan 2016
I dropped the tank to do it right.
Diablo - 2013 Camaro 2SS
Mod List: GM NPP Dual mode exhaust(Fuse pulled), AGP Twin Turbo 54/57, ZL1 Fuel pump with flex fuel sensor, ADM FPCM, ID1000 Injectors, diamond racing forged pistons, BTR twin turbo cam stage 2, Lunati forged H beam rods, BTR trunnions, ARP head studs, Vararam power wedge, MightyMouse Wild catch can, PFADT 1.25" drop springs, BMR Strut tower brace, 20x10.5 Giovanna Mecca rear and 20x9 Giovanna Mecca fronts, R1 Concepts drilled and slotted rotors, Hawk HPS pads, Night Owl RGB halo kit, and more... Future Mods: Dual fuel pump and more... |
#8 |
![]() ![]() ![]() ![]() ![]() Drives: 2013 Camaro SS Turbo Join Date: Apr 2014
i just used a pair of tin snips very easy to do
#9 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 2SS, 2017 Silverado LTZ Join Date: Jan 2007
I also dropped the tank.
#10 |
I cut my access port during lunch today. Took me about 45 mins. Slower because I have a pidly small air powered dremel. I paid attention to the pictures floating around here and knew where cables and hoses were. The gas tank sits about 1/4 - 1/2 inch below the metal you are cutting. So if you go slow and easy you will be fine
#11 |
![]() Drives: 2010 2SS Join Date: Oct 2014
I've never understood why people would take on the task of upgrading an expensive car, with expensive parts, and do so by taking shortcuts
#12 | |
#13 |
![]() Drives: 2014 SS 1LE Join Date: Apr 2014
Yea i used this to make an access hole. So no sparks or unwanted holes in the tank.
https://www.harborfreight.com/14-gau...ars-68199.html
#14 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2009 ZR1 Join Date: May 2010
My life will be easier if I need to replace a pump or go triple.
| Tags |
| fuel pump access hatch., fuel trap door, trap door |
