Old 06-09-2017, 11:37 PM   #1
Moreair1
Moreair1's Avatar
Drives: 2011 ss convertible
Lme fpcm install on vert
Has anyone installed a lpe fpcm on your Vert, if so where did you mount it since the lpe fpcm is significantly larger than the stock One, then you throw in the fpcm is mounted differently than the coupes
Cai intake and a few other mods😎
Moreair1 is offline   Reply With Quote
Old 06-10-2017, 10:05 PM   #2
PDXSSCE
Yee-aay-ee!
PDXSSCE's Avatar
Drives: 2015 2SS/RS CV CE
Originally Posted by Moreair1 View Post
Has anyone installed a lme fpcm on your Vert, if so where did you mount it since the lme fpcm is significantly larger than the stock One, then you throw in the fpcm is mounted differently than the coupes
Sorry what's a lme fpcm?
PDXSSCE is offline   Reply With Quote
Old 06-10-2017, 10:31 PM   #3
Moreair1
Moreair1's Avatar
Sorry spell check on the phone lpe twin pump fuel pump control module
Old 06-10-2017, 10:46 PM   #4
PDXSSCE
Yee-aay-ee!
PDXSSCE's Avatar
Old 06-10-2017, 11:09 PM   #5
Moreair1
Moreair1's Avatar
Stock vs lpe
Old 06-11-2017, 09:51 AM   #6
Moreair1
Moreair1's Avatar
Final spot
Old 06-11-2017, 09:52 AM   #7
Moreair1
Moreair1's Avatar
Just barely enough clearance
Old 06-11-2017, 03:43 PM   #8
PDXSSCE
Yee-aay-ee!
PDXSSCE's Avatar
Stock vs lpe
Please educate me... Is it for a modified engine? What's the advantage?
Old 06-11-2017, 04:46 PM   #9
Moreair1
Moreair1's Avatar
I replaced the stock fuel pump with a lpe twin pump set up (maxed out the stock pump and bap), the lpe fpcm or fuel pump control module help drive the pump(cts-v pump) correctly
