![]() Drives: 2010 Camaro 2SS LS3 (Stock) Join Date: Mar 2017
5th Gen Stock H-Pipe
So I have been debating on upgrading my stock H-Pipe to an X-pipe, but I was also thinking of just making them both separate (straight, no joining whatsoever). I am looking for a better and louder growl without a set of upgraded headers. Any suggestions?
Instagram: Sangstah
Do not straight pipe, you will lose backpressure and feel the loss in power/torque. I made that mistake, it sounds way louder but drives like crap. I put in a X pipe and I love it.
![]() Drives: 2012 camaro ss Join Date: Mar 2017
The factory cats are the biggest noise restriction. I tried muffler delete then resonator delete with x pipe. Finally happy with headers no cats x pipe flomaster axle back.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 CGM 2SS/RS LS3 Swapped A6 Join Date: Sep 2016
Yup.
Doesn't matter how many times you tell people, they will still do their exhaust starting at the rear, lol. As for the mid pipes? Do not go with a true dual setup, you will regret it. An X-pipe is where it's at.
2010 CGM Camaro 2SS LS3 Swapped A6 - GPI LS3 SS1 .647/.638, (224/237, 112 +4, 7Ί overlap) on CamMotion 8620 core, BTR Platinum .660" Dual Spring kit w/titanium retainers, CHE bronze trunnion upgrade, stock heads milled @ .015, Melling HV 10296 oil pump, TSP 1-7/8" long tube headers (W/Catless Off-road Pipes), Corsa Xtreme 3" Catback, GPI Ported/Rod Mod Intake, Stage 2 Ported Throttle Body, Vararam OTR CAI, Mike Norris Gen 2 catch can + GM 1LE clean side separator, 160Ί thermostat - Megan Racing adjustable coilovers (lowered 1.75"), MRR M017 10/11" wheels-Tuned by Ryan @ GPI
![]() ![]() Drives: 2012 SS/RS MN6 Join Date: Mar 2016
Cam lol
#6 |
![]() ![]() ![]() Drives: 2011 2SS/RS Join Date: Feb 2016
I must be crazy. the Xpipe scavanging sounds bad to me. Sounds bad. The lope sound sounds great.
#7 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 13' 1LE Join Date: Apr 2012
Get mid pipes 10-15rwhp and more sound. Xpipe will gain 0 but might change the sound to a more high pitch note. Stock Hpipe is nice.
13' 1LE
Old setup: TSP 231-236/Tick 660/.105 PR, UDP, SW LT 2'' & HFC, stock NPP & H pipe, VR-DRX CAI, air scoop, Goertz1 manifold, 102mm BBK, 26" Toyo DRs, Forgestars R17x10 & F18x8, rear seat delete, remote Pat G tune Autocal, 7400 limiter, Spec Mini Twin. 91oct. 11.90@122.3, 0-60ft 2.0 / 11.99@123.6, 0-60ft 2.1 DA+819 ...519RWHP SAE Solid roller SBE LS3, FED, LLSR, 91oct, 605rwhp N/A. Tuned by Pat G. Build by me. |
#8 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: Savitar; The 500rwhp N/A Monster! Join Date: Aug 2016
X-pipe is the most beneficial for scavenging gases it seems, that is why most catbacks incorporate them. H-pipe sounds better imo though. According to Janetty, the differences are negligible between the two. However, switch to straight pipes with no scavenging isn't recommended for reasons stated above. Get yourself some headers and cats/no cats, and a good catback. Should cure your search for the perfect sound.
If you wanna get crazy, throw a cam on top of that haha
*SOLD*504HP/433TQ | Night Fury cammed Cold Air Inductions intake Bo White ported TB Speed Engineering 1 7/8 longtubes NPP catback QTP low profile cutouts Powerbond 25% UDP 3.73 gears JRE scoop ZL1 grille R1 Concepts drilled/slotted rotors built/tuned by Weapon X Motorsports
#9 |
![]() Drives: 17 1LE, 17 BMW 340, 18 F-150 Join Date: Nov 2017
Sorry for bumping an old thread, does the stock H-Pipe have any cats in it? Or are there only two cats in the entire system both in the stock exhaust manifold? Reason I ask is that the SCCA Auto-X rules allow you to change out the exhaust downstream of the last cat only. So I’m trying to figure out if I should be buying an entire cat-back system with an x-pipe or just an axle back system. Can’t find any good pictures of stock Camaro H-Pipes. This would be for a 2015 1LE.
And on that subject any good recommendations for a cat-back that’s light, actually picks up some power and isn’t loud? |
#10 |
![]() ![]() ![]() ![]() ![]() Drives: 2012 M6 Camaro SS (RIP) Join Date: Nov 2014
I got the stock mid pipes and honestly the car sounds fine
You're not gonna gain anything by buying mid pipes, and X pipes lose a lot of sound if you like sound
Speed engineering 1 7/8 LTs, CAI inc Cold Air Intake, offroad connectors, Solo performance axle back with J pipes, tune, and in need of a driver mod LOL
#11 | |
雪の玉
Drives: '22 Z71 RST Silverado Join Date: Feb 2011
Found this photo on the net. It's very simple....exhaust manifolds....dual cats.....cat back.....That' it. |
#12 | ||
| Tags |
| 2015, 5th, camaro, exhaust, generation |
