Old 06-14-2017, 12:11 PM   #1
Inspiro
Drives: 2012 Camaro SS
Tools for DIY cam swap for L99
Hi
I will be doing a VVT cam for my L99, at the same time will be deleting the AFM, replacing the springs and upgrading the trunnions at the same time
I've done a few overhauls before(none on GM V8s though), and all were on engine stands
What-other than handtools- will I need to perform the job easily with engine in the car?
as a start, the Crane cams valve spring compressor looks like a good investment
Waiting for your suggestions
Thanks in advance
Inspiro is offline   Reply With Quote
Old 06-14-2017, 05:18 PM   #2
hammdo
'It's an experiment'
hammdo's Avatar
http://www.camaro5.com/forums/showth...=385577&page=5
Start at post #68. I did heads, cam, timing chain, lifters and super charger. You'll see all the tools I used. Goes to about page 15.
Also ck out RobertWays ls3 cam install. It is THE guide for cam swaps..
-Don
747 RWHP 794 RWTQ
Old 06-20-2017, 09:44 PM   #3
Jrichards73
Jrichards73's Avatar
Drives: 2011 2SS/RS Victory Red
Getting the ac condenser out of the way without disconnecting it was the hardest part...
Get a flywheel lock...
Updates: BTR Stage 2 VVT Cam Kit w/Smith Brothers Trunnions, Fluidampr, RX catch can, B&M Trans pan mod, Kooks Black Headers, Borla S-tunes, Eibach Multi-Pro-R2 coilovers and Swaybars, BMR Full Bushing kit with Toe and Trailing arms, RB Rotors w/EBC Pads, GForce 1400 Axles (now on order). AVH-X5800BHS in Scosche GM5201AB.
Jrichards73 is offline   Reply With Quote
