Old 06-14-2017, 04:47 PM   #1
Cash, Gas & A SS
Drives: ---
Power Loss w High Fluttering Idle
Hi.
I have reduced power, poor economy and a bad idle. I have come here seeking suggestions or ideas.
There is some necessary backstory to this however. These issues began immediately after I serviced my AC compressor belt. It was squealing - dislodged its tracks. I did this from the top, not from below (which I now regret) meaning I took off my air intake manifold and serpentine belt. I disconnected my MAF and pcv hose in the process. Note that the first time I started the car after servicing my belts I left my MAF disconnected. I tried blowing on my MAF with compressed air as in hopes that would help but it had no effect. I have a couple other ideas but I thought I would come here first.
After the self-service I had a CEL (P0113) which was for air intake temperature circuit. I have had this looked at by a dealership and they said it was okay and cleared the code for me. However, the issues of reduced power, poor economy and a bad idle still persist. (Bad idle means that the tach and engine rpm flutters). I asked local dealership mechanic about the bad idle but he couldn't offer a straight answer. He advised me to not waste money on the issue as "old cars get this way". With this being said, the loss in power and weird idle are NOT NORMAL, especially since the symptoms occurred immediately after I tired self servicing my belts.
Fluttering Idle when hot
Let my car sit overnight to cool and the idle is very high but drops down eventually as it heats
This vehicle is a bone stock 2011 V8.
Cash, Gas & A SS is offline   Reply With Quote
Old 06-14-2017, 05:20 PM   #2
StingrayblueSS
StingrayblueSS's Avatar
Drives: 2013 Camaro SS
Have you tried disconnecting the battery.
StingrayblueSS is offline   Reply With Quote
Old 06-14-2017, 05:27 PM   #3
Cash, Gas & A SS
Drives: ---
Yes, I did before going to the dealership but I will do it again tonight when I get access to wrenches.
You're thinking MAF reset?
Old 06-14-2017, 05:40 PM   #4
StingrayblueSS
Yeah, are you sure you put the maf in the right way?
Old 06-14-2017, 05:55 PM   #5
Cash, Gas & A SS
Drives: ---
100%, it only will fit one way
Old 06-14-2017, 06:19 PM   #6
Avenging Orange
Avenging Orange's Avatar
Idle looks normal.
https://youtu.be/9JD9it6SmB8
https://youtu.be/xmelTlEzI34
Old 06-14-2017, 10:21 PM   #7
Cash, Gas & A SS
Drives: ---
Just did it - no change.
Old 06-14-2017, 10:25 PM   #8
Cash, Gas & A SS
Drives: ---
Originally Posted by Avenging Orange View Post
Idle looks normal.
Hi thanks for your reply.
But how would you explain: Vehicle surge at low rpm? Bad mileage? Don't know exactly what mileage I'm getting right now but will check now by setting a mile counter.
This only started for me after servicing my belts. How many stock camaros do you know of with similar idle?
I was thinkig maybe a vacuum leak at the pcv somewhere. The issues with vacuum leak are all consistent.
Old 06-15-2017, 03:52 AM   #9
Bulldogge
Bulldogge's Avatar
Drives: 2011 2SS/RS CGM
All of the symptoms sound like your MAF sensor went bad. Might need to replace it. A little over $50 from Amazon.
Too many mods... Or perhaps not enough. Just one more.
Bulldogge is offline   Reply With Quote
Old 06-15-2017, 09:14 AM   #10
InFiD3ViL
InFiD3ViL's Avatar
When you left the MAF disconnected on accident, is it possible it got caught up in the belts or rubbed against a pulley when you started it? Did you check the entire MAF cable?
I have done this before myself and have come very close to getting my entire MAF cable ripped apart.
Old 06-15-2017, 09:53 AM   #11
Cash, Gas & A SS
Drives: ---
Yes it is possible (I also was curious if you guys thought dust in the MAF clip could be the cause). I tried visually inspecting but this only goes so far. I don't own a multimeter so I can't check either if there is ohmic continuity.
Did you just go to a service center and ask them to rewire it?
Old 06-15-2017, 10:01 AM   #12
Cash, Gas & A SS
Drives: ---
Could not find a clip however found this. This would be what I need if I was to redo wiring correct?
http://www.gmpartsdepot.ca/a/Chevrol...L/CD10200.html
Old 06-15-2017, 10:06 AM   #13
Avenging Orange
From your video....your idle is normal for a V8. No idle stays dead on steady. All modern cars have a high idle at cold start.
As always....I recommend eliminating the obvious. Check all connections....clean your maf and give the computer some miles to adjust.
Old 06-15-2017, 10:48 AM   #14
Olddudesrule
Resident nomad
Olddudesrule's Avatar
Drives: 2014 Summit White 1SS/1LE
Agree with this^. That tach signal "flutter" seems normal, as does the cold start readings. Since you haven't really described the "lack of power" or the mileage drop, hard to quantify that....
Sold:
2007 Z06
2002 Viper GTS/ACR
2003 Z06
1965 FFR Cobra
2012 Nissan 370Z
ADM LSA Stage II, Roto-Fab CAI, Kooks LTH/HFC's, Phastek CC, ported TB, Mishimoto radiator and oil cooler, BC Racing ER Series CO's, JPSS 32mm Black Magic rear bar, JPSS front inserts, R1 Concepts Premier slotted rotors/Goodrich SS lines, Schroth ASM harness, MGW flatstick, Brey-Krause HB, Tuned by NicD, at Cordes Performance Racing.
Olddudesrule is offline   Reply With Quote
