Old 06-15-2017, 10:43 AM   #1
xc_SS/RS
Drives: 2010 Camaro SS/RS
RevShift Transmission Mount Insert
Just installed this yesterday:
http://www.revshift.com/product-p/pti-cam.htm
This was needed for sure! First start you can tell something is different, and the first drive was very different. I thought the exhaust pipes were touching under the car lol.
Install was very easy, just had to raise the transmission a little bit with a jack to slip the insert into the mount. Very tight fit, so be prepared for some vibrations at first.
Not even 24 hours since it was installed and I can already tell it is breaking in. Shifting overall has improved, less notchy feeling with a more direct action. Throttle response has also improved and this insert paired with the shifter bushing from Pegasus CNC (google it, totally worth it) makes for a much needed improvement in shift feel/action.
Do it already.
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53
xc_SS/RS is offline   Reply With Quote
Old 06-16-2017, 12:09 PM   #2
ZX1truth
ZX1truth's Avatar
Drives: 2010 2SS/RS
I just installed mine a month ago.......love it.
LME built LSX427 w/t all Callies internals| AGP 65/65 TT | Holley Sniper Intake | Brodix BR3/LME custom ported | LME custom cam | Pro EFI 112 ECU | ID-1700x | NGK BR7EF | AGP's-Fore Triple Fuel pump | Monster LT1-S Triple | ZL1 3.23 diff, CF driveshaft, ZL1 axles | Hurst Line Lock | MGW Retro Short Throw | Pfadt solid subframe mounts | Prothane Motor Mounts | Revshift Poly Trans insert | Ground Control camber/caster plates | Accelerated Racing Solutions tuned|
God is too good! I don't deserve it, but I sure will accept it!!!
ZX1truth is offline   Reply With Quote
Old 06-16-2017, 02:35 PM   #3
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
Got the Pegasus Bushings already installed and just ordered this from your guys recommendation!!!
Orange Krush II
Old 06-16-2017, 04:11 PM   #4
xc_SS/RS
I really like it, I just wish it came in blue like they have in the pictures lol
You won't be disappointed, but know that it'll be a little vibrate-y at first since you've got the shifter bushing. I was a little surprised at first but it's much smoother even after two days. Give it a week and I bet I won't even notice it anymore.
2010 2SS/RS
Old 05-26-2020, 04:13 PM   #5
Scotty D
Drives: 2014 1le 1SS CRMT
Is it really that easy just raise the transmission and slide it in ..Do I have to slide it in from the front or the back?
Scotty D is offline   Reply With Quote
Old 05-26-2020, 05:16 PM   #6
larry_g
larry_g's Avatar
Drives: 2014 1SS/1LE
I bought a new mount and still had to press it in with a bench vise before swapping it out.
Sent from my Pixel XL using Tapatalk
Old 05-27-2020, 10:30 AM   #7
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
It’ll cause some drone I had mine in for two weeks an had to take it out, but use it for track days.
Orange Krush II
Old 05-27-2020, 02:59 PM   #8
Scotty D
Just put mine in today all polyurethane bushings need miles on them for them to loosen up a little bit
Old 05-28-2020, 08:37 AM   #9
Black_SS10
SomeguyK
Black_SS10's Avatar
Drives: 2010 Black 2SS/RS
I still have mine in a box. Keep forgetting about it.
More to come.
Black_SS10 is offline   Reply With Quote
