![]() Drives: 2015 camaro 2ss Join Date: Jun 2017
camaro 2SS NPP exhaust system
this may have been posted but I cant find an intelligible answer. I was wondering I want to make the camaro louder but I cant find a straight answer. It is a 2015 camaro 2ss with the NPP exhaust system. Does the npp exhaust system have resonators? Is it worth replacing if there is. I already pulled the fuse to keep the flaps open as well.
@LS.ACE
Drives: 2014 Chevy Camaro 2SS/1LE Join Date: Jan 2017
im sure someone else would have a more detailed answer. But you could always get a set of longtube headers and that should do the trick.
Tri-County Camaro SWFL
I do not believe any SS manual car has resonators. You can do whats called "the NPP mod". you literally cut the muffler open and put a 3in pipe in place of the OE straight though pipe. A lot of Vette guys do it. Heres a link to the muffler mod https://www.corvetteforum.com/forums...ideo-pics.html
Also theres the longtube way or high flow cats. My car read 97DB at an autocross event only have Solo high flow cats. Not exactly sure where I was at when they got me measured because they hide the meters and turn them on during your run.
Instagram: Sangstah
high flow cats and a x pipe will really wake the car up
![]() Drives: Ashen grey, 1SS, L99 Join Date: Aug 2016
If you pulled the fuse, its pretty much all you can do to the NPP without changing out to another cat-back. NPP does not have any resonators, just a H pipe crossover. Changing the stock H pipe to a X pipe will only change the tone. Your going to need long tubes, high flow cats, or cat deletes to get more volume. Besides, once you start messing with the front you'll start adding power.
Roto-fab big gulp, Nick Williams 102mm TB, Kong X-port LSA, Ported 821 heads, BTR stage 4 V2 pd cam, 416 CI bottom end, original block. TSP 2” long tubes, Corsa ZL-1 catback. Nitrous Outlet 102mm plate kit/100 shot JUST IN CASE. NGK BR7EF plugs with Taylor plug wires. DSX flex fuel kit, DSX aux pump, zl1 in tank. deatchwork 1000cc injectors. B&M deep trans pan, stock 6L90 converter, ZL1 diff 3.23 ratio. GM ground effects, T-Rex upper grill, Z/28 Spoiler, Forgestar F14s, 12” subwoofer, and custom paint matched interior.
