06-16-2017, 08:12 AM | #1 |
Drives: Camaro and Sierra Join Date: Jul 2012
Springs and Trunion upgrade
I'm running the GPI SS4 cam.
So my springs are getting close to the point I need to replace them and I had done the comp cams trunion upgrade which I've now seen to many failures to keep in my car. Anyone have any feedback on straub trunion Kit? What's springs is everyone using with their ss3/4 cams? |
06-16-2017, 09:26 AM | #2 |
Drives: 2011 camaro ss convertible Join Date: Oct 2015
I just installed an ss3 and the straub bushings 3k miles ago so I can't say how long they last or how well they've been doing because I haven't pulled the valve covers since the install. But when I got them they looked really good quality and was easy to install with no trouble. And for springs I'm using the btr .660
06-16-2017, 10:22 AM | #3 |
Thanks, btr is way I was looking to go
06-16-2017, 10:35 AM | #4 |
Drives: '10 Camaro 2SS Join Date: Jul 2013
Btr spring kit. I believe btr makes their own bushing kit now. Thought I saw one in an email I got from them a few weeks back
06-16-2017, 05:14 PM | #5 |
Drives: Savitar; The 500rwhp N/A Monster! Join Date: Aug 2016
Using the BTR .660 spring kit with titanium retainers and went with the Straub Bronze trunion upgrade. I've only had the cam about a month but everything is smooth so far
*SOLD*504HP/433TQ | Night Fury cammed Cold Air Inductions intake Bo White ported TB Speed Engineering 1 7/8 longtubes NPP catback QTP low profile cutouts Powerbond 25% UDP 3.73 gears JRE scoop ZL1 grille R1 Concepts drilled/slotted rotors built/tuned by Weapon X Motorsports
06-16-2017, 08:06 PM | #6 |
Drives: 2011 2SS/RS Victory Red Join Date: Aug 2011
BTR VVT stage 2 with Bronze Straub trunnions for over a year old and other than the engine making too much power for the axles and a throttle body that lost 5v ref, car has been running great. (both issues fixed)
Updates: BTR Stage 2 VVT Cam Kit w/Smith Brothers Trunnions, Fluidampr, RX catch can, B&M Trans pan mod, Kooks Black Headers, Borla S-tunes, Eibach Multi-Pro-R2 coilovers and Swaybars, BMR Full Bushing kit with Toe and Trailing arms, RB Rotors w/EBC Pads, GForce 1400 Axles (now on order). AVH-X5800BHS in Scosche GM5201AB. |
06-17-2017, 03:03 AM | #7 |
Thanks for info. Seems you have about the most mileage to really go off of.
06-17-2017, 08:58 AM | #8 |
Drives: 2015 Camaro 2SS Green Flash Edition Join Date: Dec 2015
GPI VVT SS1, BTR .660 springs, and went with Straub trunions w/solid bushings. About 2K miles and good so far.
A buddy went with CHE trunions w/solid bushings. Both Straube and CHE are very good quality, but I'll give CHE bonus points for impressive precision and not having to press fit the bushings. They fit very snug, but no pressing needed (you still have to press out the oem needle bearings). You won't go wrong with either one.
Kooks stepped headers & Solo XL Cat-back
ADM CAI w/race scoop & Rotofab w/w relo GPI VVT SS1 cam and CNC ported heads milled .30 BTR .660 springs, Straub solid bushing trunions GPI rod-mod intake with I-M heat sheild Circle D 258mm Pro single disc 3700 rpm stall converter 169F thermostat & manual fan switch Tuned by Ryno at GPI - 455 RWHP / 416 lb-ft |
07-08-2017, 06:44 AM | #9 |
Drives: 2015 2SS/RS/1LE Join Date: Feb 2015
Was looking at Straub, can't swing the cost for CHE. I'll deal with having to use a press before I spend $400 on bushings!
Looks like BTR is carrying a kit from Smith brothers, with micro-polished and hardened rocker shafts, and priced right. I'll probably swap these in sooner than later: https://www.briantooleyracing.com/sm...grade-kit.html
2015 SS/RS/1LE
HSA delete, VMAX throttle body, CAI inc. Intake, PRC255 heads, BTR 660 springs, BTR cryo-treated rockers, PAT G 232/240 .654/.626 110+2, johnson 2110's, Manton 502 pushrods, C5R, Melling high volume/high pressure, Powerbond 25% underdrive pulley, Proform covers, Kooks stepped headers, catless mids, Doug Thorley exhaust. 512rwhp, 446rwtq on a mustang dyno, tuned by Cunningham motorsports. |
07-08-2017, 06:58 AM | #10 |
Drives: 2010 SS 2SS M6 Join Date: Aug 2016
Powell Machine bronze bushing kit...ebay...going on 6 mo...zero issue...7k shifts at will...check out Texas Speed's new micro polished double spring kit good for .660...was and may still be on sale and IMHO same as BT kit....good luck!
07-09-2017, 05:59 AM | #11 | |
Dan
Drives: 2010 Camaro 2SS IOM Join Date: Nov 2013
CHE is only $70 more from Texas Speed.... The new CHE design does not require a press fro installation. I can remove the old trunions using a large C-Clamp...
Dan
2010 IOM SS YSI-B, Pat G Cam, Ported CTS-V Heads, ARH LTs MBRP 3" exhaust http://www.camaro5.com/forums/showth...&highlight=ysi |
07-09-2017, 08:13 AM | #12 | |
GPI 416 w/Custom GPI Cam, GPI Ported Heads & Tuned by Ben, Holley Dominator ECU, Mag Heartbeat, ZL1 Fuel Pump/DSX Aux Pump, NW 103 TB, FIC 1650's, Alky Meth, Rossler T400 w/t-brake, Circle D Converter, Kooks Headers, Viking Coil Overs & all the BMR Goodies in the rear, Zl1 3.23 Diff, DSS Axles, Wiles Racing Driveshaft, Hendrix Offset Diff Bushings, AFE Solid Subframe Bushings, 875HP/843TQ 5FDP |
