Old 10-30-2009, 02:11 PM   #1
Anthony @ LG Motorsports
Drives: 1994 1LE / 2006 Z51 Corvette
**New CenterLock wheels from ForgeLine and LG Motorsports**
Hi guys,
Tired of blending into the crowd, and a custom set of ForgeLine wheels just isn't enough?
Check out the new Center Lock option!
This feature can be added to ANY Forgeline wheel, Premier, Street, or Competition series at this time.
The package will come with the required adapter, nuts, drive pins, and socket. You have your choice of either a hex nut (with socket), or the more classical three sided 'knock off' for those doing a more historical setup. Nuts can be had in a number of colors to match or complement your wheel color as well. Just like the race car versions these are also side dependent as well (left side is right hand thread, right side is left hand thread).
This is a new feature however it is in production now so we are ready to go on almost every make and model!
Call for details on this or any Forgeline wheel!
Anthony @ LG Motorsports is offline   Reply With Quote
Old 10-30-2009, 02:15 PM   #2
Indpowr
Drives: Corvette C6
Cool
Old 10-30-2009, 02:32 PM   #3
Mr Twisty
Mr Twisty's Avatar
The real deal!
-- Benjamin Franklin
lib·er·ty
/ˈlibərdē/
noun
1.
Old 10-30-2009, 02:50 PM   #4
speedster
SST...
speedster's Avatar
Drives: SST Camaro 2010
Look very cool. Something tells me NHRA tech inspectors would never go for it... ForgeLine makes good stuff.
Old 10-30-2009, 07:06 PM   #5
tones2SS
tones2SS's Avatar
Thumbs up
Originally Posted by Anthony @ LG Motorsports View Post
Hi guys,
Forgelines are AWESOME wheels.
And that Roadster Shop Corvette is nasty!
Old 10-31-2009, 08:29 PM   #6
nl12
Drives: Unicycle
does it save weight?
nl12 is offline   Reply With Quote
Old 11-02-2009, 01:01 PM   #7
The adapters are going to add some weight (about 2-3 lbs per corner), but you will save weight by not having 5 nuts per wheel, as well as the material removed on the wheel for the center lock conversion. If anything it would cancel the weight of the adapter out.
Old 11-02-2009, 05:05 PM   #8
Petersimov
Drives: 2ss
do u have any pics of a camaro
Petersimov is offline   Reply With Quote
Old 11-03-2009, 05:01 PM   #9
I believe there is one at SEMA right now, as soon as Scott get's some pictures of it I will pass them along.
In the mean time.....
This car should have the center locks on it....do not have final pictures yet
Old 11-04-2009, 12:56 PM   #10
Another gentleman here grabbed some pictures of the WD40 car.
Old 12-18-2010, 11:20 PM   #11
zebra
just can't seem to leave
zebra's Avatar
Drives: your mom wild!!
so what would a set of center lock SP3Ps weigh in 18"x9.5" and 19"x12" with C5 Z06 offsets?
also, are they able to make them with a smooth lip instead of having the bolts?
last question - how much would a set of these run with the above specs, a satin black face with gunmetal lip, brushed silver GT nut, and black letters on the center cap?
this is for a 2000 FRC corvette, by the way
i know it's a lot, but i appreciate your time.
Eve ('00 FRC): hot-air intake
Old 12-23-2010, 02:45 PM   #12
Almost any of the wheels can be had with hidden hardware so that isn't a problem to do if you don't want to see the bolts around the edge.
Weight is going to figure on what kind of finishes you want on the wheel. Of course a chrome wheel is going to be heavier than a polished wheel. The P wheels are going to be slightly heavier than the S, and again more than the R race wheels. I would figure about 23 lbs for each front and 24 for the rears. Also depends on what you need for brake clearance...wheels built with high pad's for wide calipers are going to have more material on them for clearance.
hit me up for LG Special pricing on them.
Old 12-23-2010, 09:51 PM   #13
55Designs
Drives: 2010
I really want to see more Camaro with these center locks even with the spinners.
55Designs is offline   Reply With Quote
Old 12-23-2010, 09:52 PM   #14
Revo1
Don't Like it? Suggit.
Drives: 2010 2SS/RS
VERY
