Old 06-16-2017, 06:06 PM   #1
Sensitive
Sensitive's Avatar
Drives: 2012 Camaro LS Black
2012 Camaro LS will 2011 SS calipers work?
I have 18' OEM wheels just got the brakes changed but they aren't brembo or anything but saw some Brembo calipers selling for $400 all four wheels it was taken off at 20,xxx miles..
Good deal or no and will they fit my car, if not what do I need to add and change?
Sensitive is offline   Reply With Quote
Old 06-16-2017, 06:38 PM   #2
BumbleBeeV62011
Drives: 2011 Camaro 2LT/RS
Change your wheels and then the brembo setup will fit your car after minor trimming of the dust shield. The $400 price tag seems like a pretty good deal for the calipers, but you will also need the bigger rotors
BumbleBeeV62011 is offline   Reply With Quote
Old 06-16-2017, 06:47 PM   #3
Sensitive
Sensitive's Avatar
I'm literally close to buying these 2010-2013 SS wheels they look pretty new with sensors.. than going to change rotors than. But confused on the dust shield ?
Old 06-17-2017, 08:43 AM   #4
bdd8401
Drives: 2015 2LT SW RS A6
First you need the 20 inch wheels then you can add the brembos you will have to trim the rear dustmshields for the brembos and larger rotors to fit search the forum or google about adding the brembo brake conversion several threads out there
bdd8401 is offline   Reply With Quote
