1LE REAR AXLE
Was looking under car today and noticed, rear half shafts are different diameters. Are they supposed to be different sizes? I bought the car used and it runs great, but what's up with the different size axles?
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2022 1SS 1LE A10 BCD WCT+PDR Join Date: Mar 2008
Yes that is correct, different diameters because the torsional loads are different between the two axles, this helps control (but not eliminate) wheel hop
2022 1SS 1LE A10 BCD WCT+PDR2014 1SS 1LE NPP RECARO SIM-SOLD1995 Z28 M6 GSC PGM-SOLD1975 NOVA COUPE 300HP 350 TH350 FLASH RED-SOLD
"KEEP THE FAITH"-Fbodfather |
I have 1LE axles on my SS and I believe the bigger axle is on the passenger side.
They are much bigger than the older SS models.
Orange Krush II
Thanks for the info guys. Thought for a while a had some mishmash of a car. I found some stuff on Lingenfelters site but nice to get it from someone else. Thanks again.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: Miss Con Ception Join Date: Aug 2016
Are there newer SS axles? When were they upgraded?
2011 1SS/RS LS3 CGM
#6 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 SS 2SS M6 Join Date: Aug 2016
There is only one difference between SS and 1LE axles...the outer CV's are larger diameter to handle out board power better since that is the CV that experiences higher loads...and the axle nut is bigger...good intermediate swap until 1000+ HP axles are needed...peace out...
BTW - right axle larger since engine tq is biased to the right do to rotational forces.....
#7 |
Yes it is the right rear. Can't believe the difference in size between them
#8 |
![]() Drives: 2015_1le Join Date: Apr 2014
Does anyone know where I can find BRAND NEW 1le axles? I can't seem to find any ..
#9 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Turbo LS3 Join Date: Dec 2009
Looks like RockAuto still has some right side Z28 axles, but I have not seen any 1LE axles for a while. Pretty sure GM discontinued them.
2011 Vert - 416/w 230/236 .612/.602 115lsa, 1LE suspension w/32mm rear bar. Z28 diff. Gen6 ZL1 brakes. |
