Old 06-18-2017, 05:23 PM   #1
Crossover1le
Drives: WS6
Another ZL1 jacking points thread..
I have the jack pad from zl1addons.com. I want to get the entire car off the ground so that I can remove the wheels to get them powder coated. Here's my plan:
Jack the car from the front drivers side pinch weld, then place jack stand somewhere under that side of the car.
Then, jack the car from the front passenger side, then place jack stand somewhere under that side of the car.
Rinse and repeat for the rear of the car.
In my head this idea doesn't seem great, just because the excessive angles that will be put on the jack/jackstands.
Is there any other way to do this? Is there a location where I can get the whole front in the air, then move to the rear and get the whole rear in the air?
Crossover1le is offline   Reply With Quote
Old 06-18-2017, 09:54 PM   #2
ZL1 Maniac
ZL1 Maniac's Avatar
Drives: 2014 ZL1 Red Hot M6
This is the way I have done it, but found out it's better to lift in smaller increments.
The ZL1 chassis is so stiff, when I would lift a corner too much, a different corner would be lifting off the jackstand....a bit disconcerting...
If there is a better way I'd like to know also
ZL1 Maniac is offline   Reply With Quote
Old 06-18-2017, 10:46 PM   #3
Crossover1le
Drives: WS6
I guess nobody lifts their cars
Old 06-18-2017, 10:58 PM   #4
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
Use ramps on the front and jack from the front crossmember under the engine, on the back use a block of wood and lift at the diff housing, been doing it like that since day one.
Orange Krush II
Old 06-18-2017, 11:47 PM   #5
ZO6 Bryan
ZO6 Bryan's Avatar
Drives: 02 Z06, 95 Trans Am, 2012 ZL1
You'll crack the belly pan on the ZL1 like that.
Bryan 2018 ZL1 M6
ZO6 Bryan is offline   Reply With Quote
Old 06-19-2017, 12:56 AM   #6
Crash76
Team 913
Drives: '14 ZL1, '15 Jeep GC, ‘22 Ram 2500
I use two jacks at same time on the front(using the jack pads)... once at desired height i put jackstands under and lower onto the stands, raise the rear from the diff, then two jack stands for the rear and lower onto the stands
I have a hockey puck on the jack I use for the rear diff...
Crash76 is offline   Reply With Quote
Old 06-19-2017, 07:06 AM   #7
Crossover1le
Drives: WS6
Where are you jacking the diff from?
Old 06-19-2017, 07:13 AM   #8
Crossover1le
Drives: WS6
There is a picture in this thread that shows the undercarriage, if you wouldnt mind showing the exact spot you guys are jacking from.
http://www.camaro5.com/forums/showthread.php?t=405847
Old 06-19-2017, 09:16 AM   #9
Crash76
Team 913
Just post the rear cover on the iron center section
Old 06-19-2017, 09:44 AM   #10
deahl001
deahl001's Avatar
Drives: 2013 Chevrolet Camaro ZL1 CRT M6
Watch this video for one option.
2013 Camaro ZL1 - CRT M6 ECF
deahl001 is offline   Reply With Quote
Old 06-19-2017, 10:21 AM   #11
SSEssence
Instagram: Sangstah
Drives: 2019 Camaro 1LE
I do one side at a time, works fine from the pinch welds
SSEssence is offline   Reply With Quote
Old 06-19-2017, 07:15 PM   #12
Crossover1le
Drives: WS6
Yeah, I dont want to have to buy to jacks. It sucks that you have to jack from the sides. That means when I work on it in my two car garage I'll have to park the ZL1 in the center of the garage so that I can access both sides. With my Vette I could just jack up from the front subframe and the rear subframe it was super easy.
