Old 06-19-2017, 08:16 AM   #1
JakeSpeed21
Drives: 2012 45th SS/RS
WideBody Tire Size
Ok Guys i need a little help. With my custom camaro.
I'm looking at Rim, Tire and offsets for my widebody Camaro. I increased 2" from the fender in front and 2" from the quarter in the rear
I would like to stay in 20's.
I have chosen rims. They come in 9 or 10.5 i would love 10.5 all around
What I've read is there are many going 275/40 +33 Front and 315/35 +35 Rear no issues on Stock.
Im looking to go bigger but i do not want issues. I'm thinking 285/40 Front +10mm and 325/35 +15 rear if i could find them. All 10.5 rims
Tell me your thoughts
JakeSpeed21 is offline   Reply With Quote
Old 06-19-2017, 08:49 AM   #2
KillboyPowerhead
Drives: 2015 Z/22
Are the fenders the same height from the ground as before? If so I'm pretty sure a stock-diameter tire would smoosh the fender when the suspension compresses, so assuming you want to make use of the wide body and have the tires sticking out (past the normal fenders) you will need a smaller diameter tire. Not sure how much smaller you'd need to go; maybe jack up the knuckle until the spring is fully compressed and measure from the centre of the hub to the fender.
If we consider that a 10" wide, +23 offset wheel fits fairly flush with the stock fenders (front) and you are 2" wider, with a 10.5" wheel I guess you could have an offset of up to -21mm or so (about 1.75" out from the +23 offset wheels)? If that makes sense then the rears could have an offset of about -13mm before they become flush with the new fenders.
Nice wheels by the way
KillboyPowerhead is offline   Reply With Quote
Old 06-19-2017, 01:48 PM   #3
JakeSpeed21
That is great information. Thank you. Since the stock fenders and quarter a are now hidden i have thought of cutting them at the top to allow them to compress further
Old 01-15-2018, 05:48 PM   #4
mantarey
mantarey's Avatar
Drives: 77corvette/2011blkcamaro
hey just saw your pics looks good. my question is when you modified the fenders, did you weld new fenders and quarters on the car or just added z28 flares to your car please let me know
mantarey is offline   Reply With Quote
