![]() Drives: 2010 Camaro RS Join Date: May 2016
2010 V6 manual transmission shifting issue
Hey guys, I have a 2010 3.6L Camaro RS 6Speed manual. I've had the car for 4 years now and I've never had an issues with it, up until now. the car has about 83k miles and lately I've been having a shifting issue, the clutch isn't sticking, slipping, or grinding the gears, Its hard to shift into gear. I struggle the must to get it into reverse and first gear. If anyone has any ideas or any suggestions that might help. It would be greatly appreciated, please and thank you !
that guy <--------
Drives: 2012 camaro V6 LS M6 Join Date: Mar 2017
synchronizers might be worn out in the trans best guess i got
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Inferno Orange 2SS/RS Join Date: Apr 2010
Has tranny fluid ever been changed?
Avenging Orange: 43 years of not buying into the Hype........and damn proud of it!! https://youtu.be/9JD9it6SmB8 https://youtu.be/xmelTlEzI34 KICKING CANCERS ASS SINCE 2015!! |
![]() Drives: 2010 Black Camaro RS Package Join Date: Jul 2015
Its the clutch. I had the same exact problem with mine. Mine has 85k miles on it. Just got the car back yesterday after a new clutch and flywheel and it works perfectly now.
![]() Drives: 2015 Camaro LT Join Date: Sep 2016
The clutch isn't releasing fully. Therefore it keeps spinning the input shaft to the transmission. The trans won't allow shifting into other gears when the input shaft is spinning. It will either be a slave cylinder, or something binding on the clutch itself. Could be the master cylinder too, or even air in the lines.
#6 |
thanks guys, and I've yet to change any fluids since I've got it, other than oil changes. The dealership said they did a complete fluid flush when the car came in. Im coming to the conclusion i will have to change out the clutch
#7 |
SomeguyK
Drives: 2010 Black 2SS/RS Join Date: Nov 2014
Can you put in to 1st and reverse when the car is off? If so that points more to a worn clutch, or like Jazzzed described.
More to come. |
#8 | |
Not too many dealerships perform such duties like they did back in the day....when the costomer was king.
#9 |
"Old School"
Drives: 2010 2SS L99 Join Date: Apr 2015
Sounds like your clutch may be not fully disengaging. When you are moving does it shift easier?
#10 |
![]() Drives: 2015 2LT/RS BVM Join Date: Mar 2015
Sounds like a clutch / clutch plate to me. Had a plate fail with similar symptoms on my first car and it left me stranded in a little podunk town. Dad ended up power shifting the SoB home. I'd get it into the shop sooner rather than later.
#11 |
![]() Drives: 2011 IBM 1LT w white Rally Stripes Join Date: Aug 2012
Clutch. I had a similar problem with the very first car I owned. The clutch was going out and had to be replaced.
#12 |
376 cubic inches of fun
Drives: 2023 Camaro ZL1 A10 Join Date: Jul 2010
Yes it's the clutch not disengaging. Fix it soon before you damage the gears.
You can go ahead and change the transmission fluid, but that's not gonna fix anything. In manual transmissions, the fluid gets very little stress or contamination. |
#13 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: Miss Con Ception Join Date: Aug 2016
The pressure plate fails. with enough use the springs loose their spring.
But no sense to replace only the pressure plate as the rest of the parts aren't far behind. Be sure the estimate includes the throw out bearing and fork. May as well get all the bits for the labor cost. Quote:
when you need to stop slip it into neutral. turn the key off after stopping (so you have brakes and steering until you stop). When it's time to go, have it in 2nd and hit the starter. And away you go. A bit of careful upshifting without a clutch can get you up to highway speeds. Anyway, sometimes those small towns can fix it quick enough and get you on the way for a lower cost than bringing it home. And they have the best breakfasts!
2011 1SS/RS LS3 CGM
#14 |
Yeah, if you're going to drop the trans, then get it all done. Clutch, slave. I'd even consider a new rear main seal. The car is 7 years old.
| Tags |
| clutch, issue, manual, shifting, transmission |
