06-23-2017, 09:23 AM | #1 |
Philippians 4:13
Drives: SLP Supercharged LS3 Join Date: Aug 2009
Need help: P0306 code
So, I just get my car back this week from having my new clutch installed. I was told to baby it for 500 miles during the break-in-period, so that's what I have been doing. I took it for a short drive yesterday and started to notice a rough idle. This went on for a little bit and then the check engine light came on followed by the Service Stabili Trak notification. I ran a diagnostic check and it came back with a P0306 code.
It was suggested to check the plug wire for my #6 cylinder which I did. I pulled it and everything looked fine and made sure I did not have a loose connection. I started the car up afterwards and sure enough the check engine light is still on and has a rough idle. Any other suggestions? I would really like to self diagnose the issue and fix it myself before I have to take this in and spend $$$. FYI... The car is supercharged and has 14,000 miles. Has never had an issue. I have the ZR1/CTS-V plugs. I can't remember exactly what plug that is. I am also running Taylor 409 wires.
06-23-2017, 11:15 AM | #2 |
ZL1 Pilot
Taylor plug wires are garbage. Throw those away. I had a set on the wifes car. 4 of them were not crimped inside at all
GP Tuning 2.5 Cam, RPS Carbon Twin Clutch, Ported Blower, Kook's Headers, Cold Air Inductions CAI, ID850's, 9.17 Lower, 2.5 Upper, JMS BAP, Pedders Front Radius Arm Inserts, Whiteline Subframe Inserts, Tuned by me with HP Tuners Idle Clip Link...........https://www.youtube.com/watch?v=gTL8S9eHwbs |
06-23-2017, 11:38 AM | #3 |
Philippians 4:13
Garbage or not, they don't seem to be my issue. I am trying to eliminate one thing at a time. Wire checked out. I just picked up a new plug. Next will to check the coil if this does not work.
06-23-2017, 12:45 PM | #4 |
Drives: 2010 Inferno Orange 2SS/RS Join Date: Apr 2010
Did you check the plug itself? Swap wires?
Avenging Orange: 43 years of not buying into the Hype........and damn proud of it!! https://youtu.be/9JD9it6SmB8 https://youtu.be/xmelTlEzI34 KICKING CANCERS ASS SINCE 2015!! |
06-23-2017, 04:19 PM | #5 |
Philippians 4:13
I replace the plug. That was the ticket. The car is idling perfect now.
06-23-2017, 04:39 PM | #6 |
06-24-2017, 08:27 AM | #7 |
Always like it when it's a simple thing
Sent from my SAMSUNG-SM-G900A using Tapatalk
2010 2SS - CAI Intake, ADM Scoop, RotoFab Washer relo. LT Headers and off-road pipes, X-pipe, Muffler Deletes, ZL1 Spoiler, Technostalgia Tail-lights
'98 T/A (Sold) - Forged 6.0ltr, MS3, P&P'd Heads/Valves, 90MM FAST/TB, Headers, 3" Y-pipe, 4" Mufflex Catback. Koni Adjustables w/GC coilovers (550/175), Strano Sway Bars '94 Z28 (Sold) ... LS1 swap (basically same setup as the T/A), TH350/3500 stall ... swapped it all into the T/A -- >> Some of my Projects My Fquick Page |
