Old 06-26-2017, 02:23 PM   #1
Unsterblich
Drives: 2012 Camaro RS convertible
Installing the vitesse.....pain in the !!!
My vitesse throttle controller came in for my 2012 RS. First step of install is removing the harness that plugs into the gas pedal. I have the gray locking clip back out all the way, but I can't get the harness to unplug. Any suggestions? I'm killing myself trying to remove it .
Unsterblich is offline   Reply With Quote
Old 06-26-2017, 02:26 PM   #2
14ssrs6man
14ssrs6man's Avatar
Drives: Summit White 2014 2SS/RS 6spd
Go look at the clip on your MAF sensor, it is the same clip, may help.
Your car must be very fast! You were haulin' ass when I passed you!
14ssrs6man is offline   Reply With Quote
Old 06-26-2017, 02:46 PM   #3
Unsterblich
That doesn't help because I can't get the maf unplugged either. Lol. Any other suggestions?
Old 06-26-2017, 02:53 PM   #4
14ssrs6man
14ssrs6man's Avatar
hmmmmm, not sure then other than working in different directions to try and break free, they are expensive to replace so I would be patient.
Old 06-26-2017, 02:59 PM   #5
jc615
jc615's Avatar
Drives: Camaro and Sierra
It's a sign you shouldn't install it
jc615 is offline   Reply With Quote
Old 06-26-2017, 03:00 PM   #6
Unsterblich
I got it as soon as finished typing my last post.
Old 06-26-2017, 03:39 PM   #7
Unsterblich
I've got it installed. But now it won't turn on so that i can program it. Anyone ever run into this?
Old 06-26-2017, 04:09 PM   #8
Kyrac0103
Kyrac
Drives: 2018 2SS A8
Sounds like you either didn't get a good connection when you plugged it in or you got a bad controller... Should have come on instantly when you turned your key on, so I would be checking your connections, maybe you broke one of the connection pins???
Kyrac0103 is offline   Reply With Quote
Old 06-26-2017, 04:30 PM   #9
Unsterblich
Yea,.....I called vitesse and they said the same thing,....the controller seems to be bad. He said they're going to send me a new one asap. I can tell it was communicating with the car due to the various things popping up in the instrument clusters message center. Very frustrating.
Old 06-26-2017, 04:43 PM   #10
Kyrac0103
Kyrac
Drives: 2018 2SS A8
Good luck when you finally do get it, at least now you know how to get it in... It is the best thing you can do for the shitty throttle response in the V6 though so you should like it...
Old 06-26-2017, 04:58 PM   #11
nosmr2
Drives: 2011 L99 SS
Total PITA to install. If I could find someone to remove it, I'd sell it.
2011 SS
ADM LSA Conversion
nosmr2 is offline   Reply With Quote
Old 06-26-2017, 06:29 PM   #12
SSEssence
Instagram: Sangstah
Drives: 2019 Camaro 1LE
it's not too bad to install, its just the weird angle and position you have to lay down in to access it underneath the dash
SSEssence is offline   Reply With Quote
Old 06-27-2017, 05:17 AM   #13
mydreamcar
My Dream Car
mydreamcar's Avatar
Drives: 2011 SIM LS3 1SS
100% agree with you. No way I can get back down there to uninstall.
CAI intake/ADM Scoop/Stainless Power Headers/Dynatech cat back exhaust/Vitesse Throttle Control/ Ported Throttle Body/QTP Electric Cutouts/ 3.91 gears and janetty rear posi/ Tuned by Janetty racing
mydreamcar is offline   Reply With Quote
