#Camaro6
Go Back   CAMARO6 > Technical Camaro Topics > Camaro Issues / Problems | Warranty Discussions | TSB and Recalls
AWE Tuning
Old 06-29-2017, 02:47 PM   #1
Vyncynt
Drives: 2016 Camaro 2SS (on order)
Weak start (2016 SS)
Took my 2016 SS to the dealer for weak start analysis. They said they ran a diagnostic on the battery, alternator, and starter, but it diagnosed normal.
After I picked up my car, there was a "Test Report" (receipt paper) on the dash with the diagnostic results. It showed this:
BAC CODE 171600
Diagnostic Mode
Test Info
CCA 700
Out of Vehicle
Flooded
Results
Good Battery
Rated: 700 CCA
Measured: 794 CCA
Measured Volts: 12.42
Amp Hours: 0.0
I read around on the forums and noticed "heat soak". I think that might be a factor because it tends to happen after my car is hot and I restart it.
It did not do this last Summer, but I'm worried that when it hits 100+ degrees this Summer that it might fail and leave me stranded.
Is there a GM bulletin or warranty covered fix for this?
2016 Camaro 2SS Garnet Red
V8, Dual Exhaust, MRC,
Nav, Sunroof, Loaded
"Ahhh! Take care to get what you like or you will be forced to like what you get!"
- Lyrics from a song from Scooter: "Apache Rock the Bottom!"
Previously owned
1998 BMW 540 w/M-series package
1991 Trans Am GTA
1985 Saab 900 Turbo (Burned leaded fuel on the Autobahn)
1985 Firebird (R.I.P.)
1976 Camaro LT
Vyncynt is offline   Reply With Quote
Old 06-29-2017, 04:27 PM   #2
Adrian97c
Adrian97c's Avatar
Drives: Wife's 14' IS 250
I live in FL, I have the weak start daily.
2016 Camaro HBM A8, 2SS, NPP, Sunroof, Kalahari Interior/kneepads, Black bowties, 56v:
-11% tint all around
Ordered • 2/06/16
Built on • 3/22/16
Adopted • 4/07/16
Sold on 2/05/16:
2014 Camaro SW L99, 2SS, RS, NAV, Inferno Orange Interior:
-Borla ATAK catback
-Range AFM delete
-15% tint all around
-Red LED interior bulbs
-55k white Cree LED fogs
-License plate LED bulb swap
-12" Sub Kit, BA amp swap
-Oracle ghosted LED sidemarkers
Adrian97c is offline   Reply With Quote
Old 06-30-2017, 10:23 AM   #3
nancygrl
雪の玉
nancygrl's Avatar
Drives: '22 Z71 RST Silverado
With the battery in the trunk would the amount of heat soak really be that much compared to an engine bay? Only askin' as I'm in the south too, haven't had an issue but only had my car 4 months.
nancygrl is offline   Reply With Quote
Old 06-30-2017, 10:30 AM   #4
bybcous
bybcous's Avatar
Drives: 2016 Hyper Blue 1SS
Is this only occasional weak start? I have the same problem.
1ss/Auto-Hyper Blue
acs carbon flash spoiler, bmr springs, gm clear tails.
Texas speed cam, 223/227 .635/.635 116 LSA, Kooks Long Tube Headers with green cats, MSD Atomic Air Force Intake, CAI Cold Air Intake, QTP cutouts. 503 hp
Best so far 11.5 at 123 with a 1.83 60ft. BMR lower and upper trailing arms and upper control arms,E85
DELIVERED 12/29/15
http://youtube.com/bybcous " no talking only racing on my youtube"
bybcous is offline   Reply With Quote
Old 06-30-2017, 06:07 PM   #5
RCF
Drives: '17 2SS, NGM, MRC, DPP; '19 F150
Think he's referring to heat soak of the starter.
RCF is offline   Reply With Quote
Old 07-02-2017, 10:37 AM   #6
nancygrl
雪の玉
nancygrl's Avatar
Ah, ok...wasn't even thinking of that, lol.
Old 07-03-2017, 09:55 PM   #7
Robert215
Robert215's Avatar
Drives: 2016 hyper blue SS
Same here.. after a good 30 mins of being on when I try to turn it right back on it will sometimes hesitate for even a half second between cranks. Dealer couldn't find anything wrong either
Robert215 is offline   Reply With Quote
Old 07-04-2017, 07:45 AM   #8
CruzySS
CruzySS's Avatar
Drives: 2016 Camaro 2ss
Noticed it turns over slightly slower than a on a cold start when the motor is hot. I'm not worried about it.
CruzySS is offline   Reply With Quote
Old 07-04-2017, 09:16 PM   #9
grnflash
grnflash's Avatar
Drives: Hard
Heat soak and a slow (... like WAY slow) starter are a well-known peculiarity of this car. Lots of people have reported very slow cranking when engine is hot, but no one—to my knowledge—has reported a failure to start. If it actually fails to start, that would be news.
'16 2SS, 6MT, MRC, NPP, sways, square 285's—and an ear-to-ear grin!
grnflash is offline   Reply With Quote
Old 07-05-2017, 06:29 AM   #10
MSboy91
Drives: Hyper Blue Metallic 2016 2SS M6
Same here people. I wouldn't too much worry about it unless it decides to not start at all.
MSboy91 is offline   Reply With Quote
Old 07-05-2017, 03:27 PM   #11
AdvanSuper
AdvanSuper's Avatar
Drives: 1SS HBM w/MRC NPP
This happens to me between autocross runs if I turn the car off. I leave it on now because it's a pain in the ass to remember to put it into track mode then comp mode.
AdvanSuper is offline   Reply With Quote
Old 07-27-2017, 12:46 AM   #12
soloknight6
SoCal HT5! SD
soloknight6's Avatar
Drives: 2016 red hot 2ss M6
I have the same issue with my car currently, but I don't believe mine is related to heat soak. Do any of you have an accessory charger plugged in? I notice that when i leave a device plugged in to the accessory charger with the engine off, even for a few minutes, the starter turns wayyyyyyyy slower. Like the charger is sapping power, or the car continues to supply power even while its off. (enough to quickly drain the battery)
I just completed a long drive from los angeles to san diego and back. traffic on the way down, traffic on the way up. engine was definitely warm, but the starter would work fine if i remembered to remove my accessory charger.
2016 2ss btw, 10k miles
soloknight6 is offline   Reply With Quote
Old 07-27-2017, 06:35 AM   #13
Adrian97c
Adrian97c's Avatar
The USB charger?
Ordered • 2/06/16
Built on • 3/22/16
Adopted • 4/07/16
Sold on 2/05/16:
-Borla ATAK catback
-Range AFM delete
Old 07-27-2017, 06:51 AM   #14
Sub
Sub's Avatar
Drives: 2017 ZL1
Normal. One of the car mags even commented on it..
My Car Blog and mods. Previous Chevys: 2016 2ss, 2015 C7 z51, 2004 C5 Z06
Sub is offline   Reply With Quote
