![]() Drives: Camaro RS Join Date: Jun 2012
Do v8 springs & struts fit a V6 camaro?
2010 CAMARO RS CGM 2LT
Drives: Camaro Justice Join Date: Jun 2007
Yes you can install a set of V8 struts and coils on a V6.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 1SS 6spd Join Date: Jan 2011
And I've got a full set of 2010 SS springs I've been looking to get out of the garage.
I don't know how far you are but for the cost of shipping, you may have them. That's the same deal I got when I picked'em up. They have about 12K miles on them. ![]() If you have a 2010 V6 it will drop the back end a good bit! |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: Race Car Join Date: Sep 2009
if you put V-8 Springs on a V-6, the Drop & Stance will be off
Sounds like a subjective statement T.C.
I've before and after photo's that say different to my eye. Shall I post? |
#6 |
![]() Drives: 2015 Camaro LFX A6 Join Date: Nov 2015
Post photos.
Anyone know if the SS springs will fit the stock v6 struts without modification or additional parts?
Cold Air Inductions CAI : Apex Air Scoop / WW Relocate Kit : JacFab Intake Manifold Spacer : Overkill 80mm Throttle Body : Overkill Tuned : MagnaFlow Cat-Back Exhaust : Elite Engineering Catch Can : ZL1 Strut Tower Brace : Custom Tunnel Brace : JPSS Caster Locks : JPSS 32mm Rear Sway Bar : JPSS Billet Radius Arm Bushings : Pegasus Solid Sub Frame Bushings : 1LE Brembo Conversion : B&M 70273 Trans Cooler
#7 |
These are not the best pre and post pics, but you get the idea. 2010's had their butts in the air from the factory, but the SS springs leveled it out pretty well. Dropped the rear end a good 1/2".
Not "lowered" by any means, but you you still have ground clearance for driveways, etc... Last 2 pics are "post" SS springs. |
