Old 06-29-2017, 11:50 PM   #1
G701LE
G701LE's Avatar
Drives: 2010 2SS/RS L99 IBM silver stipes
My new supercharger build!!
Well guys and gals,
I finally started on my Kraftwerks build. I tore everything down tonight and the kit will be here tomorrow (missed the delivery today). I am putting demon eyes and angel eyes in along with the fogs.
The only thing holding me back is the harmonic balancer. I don't know if I'm just tired, but I can't get that damn thing off!!! Any and ALL advice welcome.
I will try to take some photos along the way and post them. But, I am real excited about this build. I just wish I had the cash to tear apart the upper end while I'm in there, but...... :(
2010 Imperial Blue w/ Silver stripes 2SS/RS L99
Mods = Not enough....
G701LE is offline   Reply With Quote
Old 06-30-2017, 12:30 AM   #2
G701LE
G701LE's Avatar
Ok. I tried the method of cranking the engine (just a bump at a time). Didn't help. Actually has me worried, because now the engine won't turn over. Unplugging the battery for the night to reset computer.
Old 06-30-2017, 01:09 AM   #3
blake-b
blake-b's Avatar
Drives: 2009 ZR1
Might be a silly question but are you using a harmonic balancer puller to remove it? If I'm remembering my battles with them, I usually had to use sockets as spacers to get them to work correctly. That was when I was using the ones you rent from autozone, etc.
I finally bought my own kit and it works well.
Old 06-30-2017, 05:23 AM   #4
racesloth
Dan
Drives: 2010 Camaro 2SS IOM
Looking forward to your results... now we need pics....
Dan
2010 IOM SS
YSI-B, Pat G Cam, Ported CTS-V Heads, ARH LTs MBRP 3" exhaust
http://www.camaro5.com/forums/showth...&highlight=ysi
racesloth is offline   Reply With Quote
Old 06-30-2017, 05:49 AM   #5
BiggFoot
BiggFoot's Avatar
Drives: 2010 Camaro (M6) 1000+ HP SBE
Good luck on the build! Time to turn up the HP!!
F-1X, Cog Drive, ATI Super Pulley/Sprag ~ 19 psi
Blower Cam
Brodix BP BR 3 Heads
Kooks LT Headers and full 3" exhaust
Fore Triple Pump Fuel System with ID 1700X Injectors - E85 conversion
DSS 9” Conversion (1400 hp axles, driveshaft, pumpkin) & Strange 3.70 gears
McLeod RXT Twin HD Clutch & Upgraded Slave
RPM Level VII
TR6060
BMR Drag Suspension Package w/Strange shocks
Carlyle 15" and M/T ET Street R radials
10.1 @ 143 mph 1/4 mile
BiggFoot is offline   Reply With Quote
Old 06-30-2017, 11:59 AM   #6
G701LE
G701LE's Avatar
Thanks. The Crank pulley bolt is being a PITA. Any tips? I will snap pics before installing today
Old 06-30-2017, 12:13 PM   #7
KTMracing09
KTMracing09's Avatar
Drives: 2SS/RS L99 ABM
I wedged a Small pull bar inside of the pulley to bind it so it wouldn't roll, probably a better method but I got tired of messsing with it myself
Rotofab CAI, 2" LT Headers/non catted, 3" Straight Pipe w/ X-Pipe, Elite Catch Can, GPI SS3 VVT, 9" 4000 Triple Disc, Yella Terra Ultralite Rocker Arms, MSD Super Conductor wires
KTMracing09 is offline   Reply With Quote
Old 06-30-2017, 12:15 PM   #8
KTMracing09
If leverage is the issue get a pole and put over the ratchet handle
Old 06-30-2017, 12:25 PM   #9
G701LE
G701LE's Avatar
Leverage isn't the issue. Pulley just spins...
Old 06-30-2017, 12:51 PM   #10
Silver2SS561
Silver2SS561's Avatar
Drives: 2011 Camaro 2ss rs
Originally Posted by G701LE View Post
Well guys and gals,
Did you get the injectors with the kit the same day?
2011 Camaro ss l99
Kraftwerks supercharger , 93oct , tsp longtube headers , catch can ,t160, eibach lowering springs . Tuned by Edgar from dmslights
Best et: 11.66 123mph 1.7 60’
Silver2SS561 is offline   Reply With Quote
Old 06-30-2017, 01:49 PM   #11
G701LE
G701LE's Avatar
Does any one know of a link or picture of how to get the crank pulley bolt off. I have tried wedging a bar in there and cranking if with no success...
Old 06-30-2017, 02:16 PM   #12
G701LE
G701LE's Avatar
A couple of tear down shots....
Old 06-30-2017, 02:37 PM   #13
G701LE
G701LE's Avatar
Damn crank bolt!!!
Old 06-30-2017, 03:07 PM   #14
blake-b
blake-b's Avatar
Drives: 2009 ZR1
I'm in KCMO. PM me your number and/or address and I'll come over and help.
