![]() Drives: 2014 camaro S's l99 Join Date: May 2015
Aftermarket Transmission Cooler W/All Fittings
This is a Derale cooler, with 6an lines and adapter fittings.
With the supplied fittings, lines and adapter you can route it two ways: 1) using your existing cooler in the radiator, you can also add this inline 2) use this instead of the factory cooler, so transmission fluid does not go in the bottom of the radiator. This gives more cooling properties than the PCM of NC cooler kit, because the cooler is twice the size and can be mounted in a better location(in the front). It fits perfectly in front of the AC condenser, and next to intercooler if you are forced induction. $140 shipped. |
