07-03-2017, 12:47 PM | #1 |
Anything worth doing?
Hi guys,
Is there anything worth doing to the stock BA audio system for $400 or less? I did disconnect the front center speaker. It actually made a nice improvement! Thanks for any info! |
07-03-2017, 12:52 PM | #2 |
Drives: 2015 2LT RS Join Date: Feb 2015
Change out the stock amp, first thing. BA amp is less than optimum!
It is what it is!
07-03-2017, 06:37 PM | #3 |
07-03-2017, 10:39 PM | #4 |
Drives: 2011 2SS/RS Victory Red Join Date: Aug 2011
Gut it, or don't touch it. Its a rabbit hole, one pill makes you too tall, the other too small and the one GM gave you doesn't do anything at all...
Updates: BTR Stage 2 VVT Cam Kit w/Smith Brothers Trunnions, Fluidampr, RX catch can, B&M Trans pan mod, Kooks Black Headers, Borla S-tunes, Eibach Multi-Pro-R2 coilovers and Swaybars, BMR Full Bushing kit with Toe and Trailing arms, RB Rotors w/EBC Pads, GForce 1400 Axles (now on order). AVH-X5800BHS in Scosche GM5201AB. |
07-04-2017, 07:40 AM | #5 |
Drives: 2011 L99 SS Join Date: Oct 2014
There are a handful of 4 channel amps that will fit. You'll need the s u b thump adapter too. And potentially a mounting adapter. It's been A while since I did mine. But if you shop around you can do that for under $400.
Or buy a Rockford Fosgate woofer with box and amp for around $180. Add the wiring kit for $25 or so and you've got money left over to dynomat or fake dynomat the trunk. But I'd go amp first. |
07-04-2017, 09:07 AM | #6 | |
Thanks for this info! It helps a lot! |
07-04-2017, 12:10 PM | #7 |
Not to be the use the search function guy, but I think someone did a detailed write up with pics on the amp replacement on here.
I'm sure there is a dynamat install writeup because I remember the guy was sore as shit the following day. |
07-05-2017, 07:54 AM | #8 |
MAGA
go check sub thump's website
they have a FARK harness you'd need, along with links detailing getting it installed - this will allow you to use existing wiring with an aftermarket amp. I'd look at JL amps. You can get away with a *nice* JL 4chan amp for $450, another $100-150 in the harness + mounting board so $5-600 can make a huge improvement to your existing sound stage as well as give you the option to put in different components at a later time (this is what i plan on doing)
“Freedom is not defined by safety. Freedom is defined by the ability of citizens to live without government interference. Government cannot create a world without risks, nor would we really wish to live in such a fictional place. Only a totalitarian society would even claim absolute safety as a worthy ideal, because it would require total state control over its citizens’ lives. Liberty has meaning only if we still believe in it when terrible things happen and a false government security blanket beckons.” - Ron Paul
07-05-2017, 08:45 AM | #9 |
I purchased this amp: JL Audio JX400/4D 4-channel car amplifier last March. It is currently on sale for $167.49 with free shipping. I'm sure there are better amps out there, but this should work in your budget. I also got my FARK from the classifieds here and saved some cash that way.
