Old 07-03-2017, 02:56 PM   #1
Fredryberg
Drives: 2010 2ss camaro
P0308 stabilitrac crapped itself
Going in to work today my car was running great passed up several cars on freeway then boom. Service stabilitrac came on. This happened once and was a loose spark plug wire. So checked plug wires they were all good and tight. Hooked up my sct tuner and saw p0308. Swapped wires from number 8 to 6. Still same problem. Should I just replace plug and swap coil and see what happens?
2010 camaro ss. 68000 miles ls3
Fredryberg is offline   Reply With Quote
Old 07-03-2017, 06:42 PM   #2
Rock-It Man
376 cubic inches of fun
Rock-It Man's Avatar
Drives: 2023 Camaro ZL1 A10
Loose plug wire? Telling us what you've modified on the car would be helpful. Plug wires don't get loose by themselves.
Rock-It Man is offline   Reply With Quote
Old 07-03-2017, 07:29 PM   #3
Fredryberg
Sorry stainless works headers and tune by dyno Steve. Car has ran flawlessly for 10,000 miles
Old 07-04-2017, 03:16 PM   #4
Fredryberg
So far I have changed out plug. Plug was fouled with gas. Switched coils, and swapped wires around still have misfire on cylinder 8. Am I prob right in guessing it's a broken valve spring?
Old 07-04-2017, 05:52 PM   #5
Jazzzed
Jazzzed's Avatar
Drives: 2015 Camaro LT
Maybe the injector is stuck open.
Jazzzed is offline   Reply With Quote
Old 07-04-2017, 06:13 PM   #6
Fredryberg
Is that a common problem? How could I test that?
Old 07-04-2017, 07:56 PM   #7
Leo72793
Drives: 2011 2SS/RS
move the injector to another cylinder is one way. Also using a screw driver to hear it tick is another. easiest ways.
Leo72793 is offline   Reply With Quote
Old 07-04-2017, 08:49 PM   #8
Fredryberg
Swapped injectors still show cylinder 8 misfiring. Any other suggestions? It idles fine gf says it smells like raw fuel from behind the car also worst than normally but I don't run cats either.
Old 07-04-2017, 08:58 PM   #9
CamaroFred
CamaroFred's Avatar
Drives: Miss Con Ception
Put your overalls on and pull the valve cover.
It isn't rocket science.
2011 1SS/RS LS3 CGM
CamaroFred is offline   Reply With Quote
Old 07-04-2017, 10:27 PM   #10
Fredryberg
Yes Fred. I'll do it tomorrow.
Old 07-05-2017, 09:30 AM   #11
Fredryberg
Size:  143.4 KBPulled off valve cover and found
Old 07-05-2017, 09:46 AM   #12
frankwjr
frankwjr's Avatar
Drives: 2010 SS 2SS M6
That is F'D!...more info...car mileage....any other mod's...original owner? I bought my 2010 at 90k on the clock...car had new '14 LS3 installed at 70k by dealer...one of the very first mods I did was the pushrod/spring/rocker bushing upgrade...why...all my research showed the biggest potential for failure was the valve train on the LS3...
Is your valve train still completely stock? I would be looking at the spring and rocker on that cyl...and I wonder what the lifter/cam lobe looks like...
good luck and keep us posted!! peace out...
Old 07-05-2017, 09:55 AM   #13
Fredryberg
2010 camaro 68000 miles headers, full exhaust, tune. Yes valve train stock. Spring still appears to be in good shape this is what makes rocker arm go up and down I am guessing. It is the pushrod that is broken. What are my options?
Old 07-05-2017, 02:48 PM   #14
Fredryberg
Got rest of pushrod out what would happen if I install a new one. The ls1 boards have told people to do so. Kinda winging it here without any advice. Making me wish I had a evo again
