Old 07-08-2017, 12:00 PM   #1
CyberGreyConvertible
Dunder Mifflin Inc.
CyberGreyConvertible's Avatar
Drives: 2012 2SS/RS Convertible
Convertible / Wicker Bill question
Hey, everybody! So, I'm looking at options in regards to spoilers for my vert (2012). Due to the antenna being right in the factory convertible spoiler, changing it out would be a bit of a nightmare. So, I'm looking at adding a Wicker Bill instead. Does anybody know if this will fit without any issues? I just want to make sure that I don't order it and find out that the install is impossible.
Here's the exact Wicker Bill I'm looking at:
https://www.amazon.com/Camaro-adjust.../dp/B015X2P1CQ
Thanks !!
CyberGreyConvertible is offline   Reply With Quote
Old 07-08-2017, 01:58 PM   #2
Reddog1982
Drives: 2012 L99 2SS
The z-28 style spoiler will work on the Convertible. There's a long aluminum anteana and a medium sized metal piece that has to be moved over. I cut a hole into the bottom of the spoiler and slid everything back in then squirted a little expansion foam to hold things in place. You'd never know it was rigged unless I told you.
Reddog1982 is offline   Reply With Quote
Old 07-08-2017, 02:01 PM   #3
Reddog1982
The anteane sits right along that portion that the screws go into but the screws will probably go through it and not really hurt anything. It's a flat piece about an inch wide and a 16th thick. The spoilers not metal so it's not going to ground the signal or anything.
Old 08-22-2020, 04:18 PM   #4
Jsltgif
Drives: 2011 Switchblade Silver 2SS/RS Conv
I found a wickerbill on eBay that fits up perfect replacing the stock spoiler. Only had to do minor alterations to it to fit the factory antenna in it. I love the news look.
Jsltgif is offline   Reply With Quote
Old 08-22-2020, 04:20 PM   #5
Jsltgif
How do you add pics
Old 08-22-2020, 09:22 PM   #6
Camaro2ss2010
Camaro2ss2010's Avatar
Drives: 2010 Camaro 2SSRS M6
Originally Posted by Jsltgif View Post
How do you add pics
Select go advanced below and select upload image. Then close that window to get back to the main screen
ECS supercharger, Texas speed stage 3 boosted cam, Johnson 2110 race style lifters, ported throttle body, long tube headers, aeromotive fuel pump, fic injectors, ATI super damper, Corsa Extreme exhaust, elite engineering catch can and many other things.
Camaro2ss2010 is offline   Reply With Quote
